Question about Whirlpool Duet GHW9150P Front Load Washer
Front loader washing machine. wet clothes stuck inside. door lock won't release.
I've had this problem before i unplugged it because holding down the lock button didn't work so unplugging it from the wall for about 20 minutes worked just fine it seemed to reset itself. good luck.
Posted on Jan 05, 2009
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
I have a hotpoint aqualtis washing machine and the door is locked how can i release it
Most washing machines wont let you open the door if there is still water in it. Try putting the drain hose on the ground to drain the water out and try the door again. If its a front loader, there may be a drain hose or outlet next to the filter cup. Usually down on the front of the machine.
Sep 17, 2017 | Washing Machines
I have a Whirlpool washing machine, front loader, AWM 323. I have just finished washing a load but cannot open the door!
If your machine is a Duet model or it's relative, first unplug the machine then remove the lower valance under the door (three screws on the botttom of the machine) reach up by the door lock and you'll find a plastic tab hanging down, that's the manual release for the door lock. Wile you have the valance off look inside the machine and pull out the technician sheets that are stuck on the inside wall of the machine, you may need them later.
Oct 27, 2010 | Whirlpool GHW9400 Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader washing machine will not go through spin cycle. door locked shut. cant get clothes out
most frount loaders have and unlock pull ring on the door latch switch, it will mean removing the bottom access panel to reach up inside the machine and pull the release ring down to unlock the door
Apr 21, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal De
