Lg 42cs460-za can i have code 4 sky remote please
Code for tv lg42cs460
Posted on Jun 13, 2013
    New Friend:
Code 0206 also works with LG42CS460
Posted on Mar 14, 2013
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
SOURCE: SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Posted on Sep 02, 2009
SOURCE: sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
Posted on Dec 28, 2010
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
EngineerMC
  • 186 Answers
SOURCE: sky remote code for lg m227wdp
press tv button
then red and select together for 2 seconds the led should blink twice
enter the code
press select
try it...
one of these codes should work... but its a bit trial and error 0056 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
good luck
Posted on Feb 14, 2010
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
Hi i have the 47LH4000-ZA can you give me the tv code fof sky remote please
hi ya just got one of these tv myself the code for sky is 0206 hope this helps
Jan 03, 2010 | LG Televison & Video
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Sky remote control code for LG tv
Can you provide me with a set up code for my Sky remote control to work my LG LCD tv model no. 32LG3000?
Many thanks
Jan 09, 2009 | Televison & Video
Sky remote codes
With an up-to-date remote (rev 8 remote) the 4-digit code 1280 definately works for the LG 32LC56 model coz i have just done it.
Jan 22, 2008 | Televison & Video
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
1,133 people viewed this question
Top Televison & Video Experts
