Can only play G movies on dvd recorder
How can I change/reset my security code....I don't have a clue to what it is.
  • 5 more comments
  • lmr635 Jan 05, 2009
    I did but it did not work, any other suggestions
    I tried 0000, 1234, 1111, and 9999.  None of these seem to work.  any other suggestions???????
  • lmr635 Jan 06, 2009
    Panasonic DMR-ES20
    DVD recorder
    Tried and no luck.  Though, the main unit only turned off, it never did say standby....if that makes a difference??? At this point I will try anything.
    Yes for about 45 minutes unplugged
    Thank you for your help, but I finally got through to Panasonic.  They had me open the disc tray and then hold record and play at the same time for 10 to 15 seconds.  I can now watch all ratings of movies!!!  Thank you for your time, hope this helps someone else in the same situation.
  • 716 Answers
Try all zeros.
Posted on Jan 05, 2009
  • 4 more comments
  • Michael Fisher
    Michael Fisher Jan 05, 2009
    1234
  • Michael Fisher
    Whats The Make And Model # Of The Dvd Player?
  • Michael Fisher
    Michael Fisher Jan 06, 2009
    This May Work.
    Reset the unit as follows:
    Press [POWER ^/I] on the main unit to switch the unit to standby.
    If the unit doesn’t switch to standby, press and hold [POWER ^/I] on the main unit for about 10
    seconds. The unit is forcibly switched to standby.
    Alternatively, disconnect the AC power supply cord, wait one minute, then reconnect it.
  • Michael Fisher
    Did You Try Unplugging It And Doing It?
  • Michael Fisher
    Please Try This Exactly As It Says Again
    I Called Panasonic And They Said This Is Exactly The Way It Should Be Done. So Please Just Give It One More Try
  • Michael Fisher
    You've Helped Adding To My Knowledge So Thank You.
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
I have panasonic dmr-ez485v dvd recorder cambo, it has F60 code don't turn on or off
Hit reset button, unplug it or swear at it. If you looked up online find more problems listed on unit then ways to correct problems. Does have nice play back. I bought a DVD maintenance kit seams to help some issues. good luvk
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have recordered many home movies to a dvd+r
Dvd+r disks are the least compatible to most devices.
Try using Dvd-r instead.
Dec 02, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Could you please tell me how to rezone my Toshiba dvr 16sb for all areas as I recieved an American movie from my daughter for my birthday and cannot play it on my video recorder. Many thanks.
First, since you are using a Recorder not just a player, the consequences of changing the region are many. Anything recorded will now be coded for the new region and will only play on that devices coded for that region. So....I would A. Play the DVD on your computer which is easily manipulated for region code changes.( http://www.videohelp.com/play)
Or B) Change the code on a player only.
OR C) The third option is to rip the DVD via computer freeware such as DVDshrink and designate the region you desire when doing so. You can then easily burn the DVD copy with the "correct" region.
Hope this helps.
Apr 08, 2008 | Televison & Video
Won't play ANY movies
separate the plug on the other appliance,check if the trouble is dvd or tv by connect other input device like game console or dvd.
Feb 11, 2008 | RCA DRC8052N DVD Recorder
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
