Door will not open
this product seems to be an audio CD player in use with a stereo system.
Have you tried inserting a paperclip (that has been straightened out) through the tiny hole available to manually coax the tray to come out. It will pop out just a little, but it will then be unlocked and be easy to bring out, displaying the entire CD.
If you have tried that, then.....
Take the cover off (the entire case) and inspect the area where the CD is. Many of these players have no metal encasement around the CD mechanism and one can see the inner workings. The CD may have gotten askew, or the mechanism jammed. Gently try to free things up.You should at least retrieve your CD.
Put the thing back together. Use a junk cd (keep the stereo amp off) and try to load and unload it. If that fails.... Time to get a new one.
Here's a suggestion for that. Most all DVD players handle cd's. Purchasing an inexpensive DVD player might be cheaper than finding a stereo component CD player. Just use the audio out.
Good luck
---Sam
Is this with ALL audio discs?
