Question about OKI B4350 Laser Printer
Oki B4350 check image drum missing - OKI B4350 Laser Printer
FrankR1974
  • 8 Answers
SOURCE: OKI PRINTER B4350
This sounds like it could be a "toner Sense" error / try removing the drum unit and cleaning the 6 contacts on the left inside of the printer
Posted on Apr 12, 2008
SOURCE: OKI B4350
Its a Thermal error. the code is Error 020 and its a problem with the main board on the printer. costly to repair if not under warranty
Posted on May 20, 2008
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
SOURCE: resetting image drum after replacing for oki b4600
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE
Posted on Oct 30, 2009
SOURCE: Error 020 on OKI B4350 printer
After pushing the on button, RAM CHK- initializing-- on-line - auto, and then, over and over and over again. It just goes in a circle.Pardon my english. Denmark is calling :-)
Posted on Feb 15, 2010
It keeps flashing check image drum drum missing, i had paper jam took out drum to remove it then replaced it but keeps flashing this message
Some drum units are "chipped" to prevent the rebuilding of of them and it's possible yours is one of these. Removing the drum, once installed, may have triggered this error message. Try emailing Oki about this; in the past they were pretty good about responding to customer problems while I was still involved with servicing these and other printers.
Mar 07, 2011 | OKI B4350 Laser Printer
Screen says change drum
Your printer is telling you it needs a new drum. Go to a search engine (Google or similar) and type:
oki b4350 drum
The results will show you where you can purchase a replacement. They look to be priced between £115 and £160. The replacement should have instructions on how to fit it.
Best of luck.
Nov 29, 2010 | OKI B4350 Laser Printer
Printer says change drum when a brand new one was put in today.
try cleaning the contacts between the drum and the printer
Apr 01, 2010 | OKI B4350 Laser Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
Oki B4350
I had the same problem and just now spoke with the Swedish OKI support, according to them it's the memory check that won't finish. This memory is located on the controller pwb and is probably more expensive than the machine itself! Change the controller pwb and the problem should be solved!
Cheers / Stefan
Aug 28, 2008 | OKI B4350 Laser Printer
Drum change
Step 1. Open Top Cover.(Press the oval button RHFront)
Step 2. Tilt Drum Unit by lifting slightly at the front.(The Toner cartridge sits in the top of this)
Step 3. Remove Drum Unit by lifting straight up.
Step 4. Insert "NEW" Drum Unit. (Steps 3 and 2 in reverse order and direction(s))
May 19, 2008 | OKI B4350 Laser Printer
DRUM CATRIGE.
If you have drum cartridge error you need to change the drumkit
Apr 21, 2008 | Office Equipment & Supplies
OKI PRINTER B4350
Apr 09, 2008 | OKI B4350 Laser Printer
OKI Printer B4350
The Solution is:
You must have the Oki Monitor Software installed
When you enter in to the software you have a button that say "Maitenace", then you have a option that says " Reset Drum Counter" or somthing similar. Click on the option and the message disappear from the display.
Sorry my bad english
Nov 23, 2007 | OKI B4350 Laser Printer
OKI B4350 Laser Printer Logo
66 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
