Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Enviro Vac Model 4470 Not Sucking
My Eureka Enviro Vac 4470 is about 10 years old and has worked perfectly until now. The problem is that it sucks debris into base, but it does not go up the hose. It is stuck at the point where the hose attaches to the base. When I detach the hose from the base and check the suction it is very weak. So if I attach an attachment and try cleaning a corner or something it sucks up nothing. Almost no suction through the hose. Have replaced the bag (of course) and the filter, but still nothing. I have stuck a hanger part way up the hose and there seems to be no blockage. Please help. Thanks.
  • 833 Answers
Re: Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
Posted on Dec 31, 2008
  • 3 Answers
Also take apart to expose motor, make sure their is no dust on top of motor, that will cause the problems u r discribing, also like Robert said check Impeller Fan and make sure fan is not blocked and is running freely, hope this helps let us know the out come and what ended up beging wrong.
Posted on Sep 09, 2013
0 characters
3 Points
What filters do I use for this? does the Hf-9 work?
Hey, this is Jeremy with Crucial Vacuum,
Unfortunately, you did not include what kinda of vacuum you were trying to make sure the Eureka HF-9 filter was compatible with. Below I have compiled a list of all of the models that the HF-9 filter will work with for you.
  • Fits Eureka Upright Style HF9 Victory & Whirlwind Vacuums.
  • Eureka Victory - 4300, 4400 & 4600
  • Eureka Victory Enviro Vac - 4370, 4377, & 4470
  • Eureka Self Propelled - 5184, 5185, 5187, 5188, 5190, 5191, & 5196
  • Eureka Whirlwind - 4180, 4380, 4381, 4480, 4481, 4483, 4488, 4489, 4580, 4686, & 4689
  • Eureka The Boss - 4672
  • Eureka Smart Vac - 4469, 4473, & 4476 & Sanitaire- S4170, SC4570, & SC4580 models.
You can purchase replacement parts for Eureka (including the HF-9 filter) direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 12, 2015 | Vacuums
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
My unit was working perfectly, then all of a sudden the heating unit quit. It's only two months old. What happened?
It's still covered by warranty, so I suggest taking it to where you got it. If they don't have a warranty station, you can find the nearest one on the below site.
Oct 05, 2010 | Eureka Deluxe Enviro Steamer Vacuum
I need a replacement hose
You can get the nose part number and order the part at this URL:
Oct 02, 2010 | Eureka 3041BZ Upright Vacuum
What is the difference between the 2 eureka enviro steamers: the 310 model, and the 313A? are they doing the same job, and which one is a better buy i.e., does the job, and does not cost an arm and a leg...
The Eureka 310 Envirosteamer is no longer made. Eureka discontinued this particular model several years ago. It was a very highly rated steam mop at the time, so Eureka came out with a new model that had a very upgrades which was the Eureka 312, which is also now discontinued. These two old models are discontinued because Eureka has introduced the 313A which is the best model they've made to date. This is the most current, and only upright steam mop that Eureka makes currently, so if you are going to buy a Eureka, the 313A is the one that you want to buy. It's a great steamer I think. We do offer a 60 day full money back guarantee with any purchase, I hope you will consider us when you're ready to go for it.
Please feel free to request a clarification here on Fixya if you have any questions I can answer further for you.
I hope this was helpful information for you. If this was helpful, please rate it as helpful by clicking on the thumbs up icon in the lower right hand corner.
Thank you so much,
Chris J.
Mar 17, 2010 | Eureka Enviro Steamer 310 Stick Vacuum
My enviro vac is being stubborn
First , spin the brush roll by hand and see if it spins freely. Then remove it.
CLEAN OUT ANY HAIR OR THREAD UNDER THE CAPS Inspect the end caps , if one is melted you will need to replace the cap if available or the entire brush roll assembly.
The "metal piece" is the motor shaft. Clean any burned rubber of with fine wet dry sand paper, then install a fresh belt, using the brush for leverage to stretch the belt into place. Rotate the brush again to be sure it is not binding and that the belt is not pinched anywhere.
Buy 2 belts and keep your spare inside the hood of the vac.
Sep 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
1,145 people viewed this question
Top Eureka Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
