Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher Paykel DD603 top drawer will not drain
My husband had to replace the garbage disposal and now the top drawer keeps filling up with lots of water and will not drain. please help!!
  • 145 Answers
Hi and welcome.
Either your hubby forgot to knock the plug out of the dishwasher connection on the new disposal, or he does not have a dual-air gap installed and the hoses to the dishdrawers do not have a high loop to prevent back-siphoning into the drawer...
Posted on Jan 07, 2009
Fisher paykel dd603
If you hear the motor sound during drain cycle then it is likely the drain hose is cracked and pump cannot generate enough pressure to empty the drawer. You will have to find the cracked portion of the hose and replace it. It appears the bottom drawer is operating properly.
Apr 11, 2014 | Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Mar 22, 2014 | Fisher and Paykel Dishwashers
My Fisher and Paykel Dishdrawer is not draining at all.
If both drawers are having the problem then it is unlikely the drain pump is the problem. You may need to check the blockage in your kitchen drain or if using garbage disposal unit then ensure it is clean and not blocking the drain.
Feb 17, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
697 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
