Question about Kenmore Washing Machines
Wash machine will not always spin dry
Washing machine will not always spin dry. only if it is light loads and not always then.kenmore model 110.20722990
  • 135 Answers
This is a problem with either the basket drive or gearcase (transmission). Usually requires a servicer, but I will help more if needed.
Posted on Jan 04, 2009
  • Kenmore Master
  • 19,396 Answers
This is often because motor problems, motor control unit problems, or if the model has a clutch also clutch problems.
If there is also noise when spinning it can also be a bad drum bearing.
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
Feb 28, 2015 | Kenmore 24032\24036 Top Load Washer
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Kenmore Washing Machines
Machine does not spin dry well
heatman101
Sep 30, 2010 | Kenmore Washing Machines
Kenmore 80 series model 22832100 does not always spin fast enougf
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Kenmore Washing Machines
My kenmore top loading washing machine won't spin
Once you remove the cabinet,remove the water pump and check it for a garment or lint. Clean or replace the water pump and reinstall it.
Oct 31, 2009 | Kenmore Washing Machines
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
