Question about Bose & Wave& Music System
One speaker doesn't work on my bose wave radio/cd?
    New Friend:
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Posted on Mar 06, 2013
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Posted on Sep 24, 2008
SOURCE: No sound
I had the exact same problem. I disconnected the radio from the power cord in the back, waited several minutes, reconnected the power cord and my radio had sound!!
Posted on Nov 16, 2008
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
  • 137 Answers
SOURCE: I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Posted on Apr 16, 2010
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Radio works fine. cd player wont read discs in either of four slots. Message - Disc error.
This can often be solved by opening the cover and blowing on the optical head to displace dust and any debris that is fouling between the optics and the actuator that controls the head position. It isn't fool proof but will fix perhaps 40% of units. Take a can of air duster (aerosol blower) and blow the little pick-up form the distance of about 1 inch. It will bounce around in the wind but don't blow to hard. Give it a gentle blast and then try the player. If it doesn't work then try again this time but blow harder.
Feb 27, 2012 | Bose Wave Music System CD Shelf System
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
We dropped our Bose Wave radio cd player on the tile floor. One speaker seems to not be working. How do we fix it? Cd player is working. Radio is working.
You probably can't repair it yourself, It definitely sounds like a qualified tech's job to me. It could be many, many reasons for the failure. As simple as a fuse popped out of it's holder to part of the motherboard cracked. The shock could loosen any solder joints. If the speakers are built in it could be a damaged speaker or anything working backwards from there. Electronics and tile floor spells expensive to me. But I could be wrong, it happened once before (only a joke)
Apr 07, 2010 | Bose Wave Radio
Cd does not play
Does the radio work? If not, make sure the volume is up. If so, the speakers are not blown. Return your product.
Oct 15, 2009 | Bose & Wave& Music System
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
Bose wave radio
phoned bose as i have similar prob, bose said remove the 9 volt batt under base leave for ten mins then plug into mains without bat and try again if this fails it needs to go to bose.
Nov 10, 2008 | Bose Wave Radio
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Bose Wave Radio/CD - Sound from only one speaker
Sounds like the audio transformer, but it's difficult to tell because Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 06, 2007 | Bose 683-0332FB CD Shelf System
Bose & Wave& Music System Logo
140 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
