Question about GE 30" Built-In Single Electric Wall Oven - Bisque-on-Bisque
I have a GE Wall Oven JKS06G0H1BG and it needs a thermostat. Where can I get that for this 26 year old oven?
  • 10 Answers
SOURCE: JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Posted on Aug 18, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Posted on Jan 08, 2009
  • 65 Answers
SOURCE: GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Posted on Jan 28, 2009
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Posted on Jun 18, 2009
Jenn Air Wall Oven W181 Thermostat
I have found the following message on GE Repair Help:
Tim
  • Refrigeraton Guru
  • Technician
xx.gif Re: W181 Oven « Reply #3 on: January 10, 2010, 03:46:04 PM » You need to measure the length of that probe. If its near 3 inches you need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=232
If its near 6 inches you will need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=233
These are replacement kits the original is no longer available. « Last Edit: January 14, 2010, 09:26:32 AM by Tim » I have already ordered the part and hope it will work. Best regards, Miro Bogavcic
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
I need to replace the "Glow bar" in my 35 year old tappan gas wall oven. Is this something I can do without taking the oven out of the wall?
Hi, As long as the wires connecting the ignitor are long nough, you can do this while the oven is in the wall. They usually come out far enough. Make sure the oven is unplugged or the breaker is turned off. It is fairly simple to change.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 11, 2009 | GE 24" Built-in Single Electric Wall Oven...
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Jan 28, 2009 | GE JKP50SH Electric Double Oven
GE Wall Oven JKP70 Locks and reads F9
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
Dec 29, 2008 | GE JTP20 Electric Single Oven
Dec 27, 2008 | GE JKS05 Electric Single Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE 30" Built-In Single Electric Wall Oven - Bisque-on-Bisque Logo
57 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
