Question about Husqvarna Designer I
Thread breaks when embroidering
When I embroider on heavy weight fabric or stretchy fabric the thread breaks. I have tried adjusting the tension up and down, making all sorts of adjustments with stablizers, checked the needle several times, tried different needles. I have noticed that it does make thrashing sounds just before it shreads the thread and breaks. I have also noticed that it normally breaks within the first 50 stiches or when the direction of the design changes.
    Problem Solver:
  • 9 Answers
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Posted on Feb 21, 2009
How can I get my janome 11000 to work when embroidering? The bottom thread doesn't even show and top thread is always breaking.
The tension(s) may be too tight and could be threaded incorrectly. Start out with a brand new needle. Be sure to RAISE the presser foot when threading the upper thread. Consult the owner's manual to be sure it is threaded in the proper order. Test your stitch on a straight stitch and adjust it so both threads meet in the middle of the fabric. This setting works for straight stitch. However, usually the upper thread tension is loosened a bit for embroidery so the bottom thread will not show on the top of the fabric. Test it on some small embroidery patterns first until it's where you want it.
Mar 05, 2016 | Janome Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
While embroidering the top thread gets wound around the bobbin and makes a nest on the bottom
have you tried changing the needle
rethread the machine top & bobbin
when embroidering make sure it good quality thread
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread your using it not knotty
make sure the tension is set for the thread & needle & fabric your using
make sure the thread has not come off the thread take up lever
Mar 17, 2012 | Brother Sewing Machines
When I start to try to embroider the red light just blinks and I can not send tothe machine
you might try youtube for video's on embroidery
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 02, 2012 | Sewing Machines
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
Am embroidering and the thread tension is off. I
describe the things you are seeing , is it pulling, snapping the thread? What brand and model is it? which attachments or feet are you using?
Oct 21, 2009 | Baby Lock Esante
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Mar 23, 2008 | Husqvarna Viking 1
Tension problem
For Staight Stitch.
Ideal
When adjusting top thread the Higher the number (on the little wheel) the tighter the top thread.
Results depend on
Stiffness and thickness of the fabric, number of fabric layers and type of stitch.
Are you using paper or a plastic bag or pellon under the fabric? This gives a smoother surface for embroidery (on the reverse) and you can cut it away after the design is complete.
Susan
Mar 18, 2008 | Janome Memory Craft 3000
Sewing Machines Logo
217 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
