Question about Home
Roman faucet shower leaking uberhaus # 70115055
  • 19 Answers
SOURCE: shower head leaks with running
the cartridge for your faucet needs to be replaced .what type of faucrt do you have?Let me know and i will try to assist further.
Posted on Feb 07, 2009
  • 659 Answers
SOURCE: Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Posted on Apr 17, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 54 Answers
SOURCE: leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Posted on Sep 26, 2009
  • 4349 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
Uberhaus bathtub and shower faucet 81585016 problem
The reason is because they built this wrong and Rona still decides to sell it. I have one in the wall that I am stuck with. Call up Mecanair, the rep for uberhaus and the they will tell you its not a mistake to have HOT water come out when the handle is at the C position.
Mar 06, 2013 | Home
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
Defective Jado classic master bath products
sounds to me as though the problem might be coming from where the drain and pop-up rod meet,..you know how there is usually some little parts i.e.; o-ring, teflon bushings, etc. that HAVE TO BE put in in order,? check that stuff out and if it fixes problem, what looked like bad a spout might not be anymore,......
Oct 30, 2009 | Jado NEW CLASSIC ROMAN TUB SET WITH HAND...
Water coming from faucet and showere head when the
the washer on back of the dirverter knob needs replacing or the seat behind the vavle stem
Aug 18, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
