Question about Microsoft Windows XP Professional
Desktop not appear
Computer start,booting comp.but desktop not appear victime of software coounterfeiting
  • 30 Answers
Try to boot in safe mode:
Push F8 or F2 when booting.
Posted on Jan 05, 2009
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
My computer says you may be victims of software counterfieting and it always erase my wallpaper desktop what should i do
Hi
The message "you may be victims of software counterfieting.... " comes out when you use illegal copy of the software, and your copy need to be authenticated.
Is the message appear for the whole Operating System (windows) or specific software?
Good Luck
May 13, 2011 | Computers & Internet
You may be a victim of software counterfeiting. This copy of Windows did not pass genuine Windows validation.
1.Restart your computer. Press "F8" repeatedly as the computer boots up, until the Windows startup options menu appears. Choose "Safe Mode" and hit "Enter."
2.Click "Start" and click "Computer" or "My Computer." Double-click your primary hard drive. Enter the "Windows" folder and the "System32" folder.
3.Scroll through the list of files until you find "wgalogon.dll" and "wgatray.exe." You can delete these files completely or, if you need WGA in the future, right-click each file, choose "Rename" and add ".bak" on the end of the file name, after the extension.
4.Click "Start" and type "Regedit" into the search box. Click "Regedit" when it appears in the search results. The Registry Editor window appears.
5.Click "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT" and "Current Version." Find the "WGALogon" folder under "Current Version" and enter it. Right-click "Notify" and choose "Delete." Restart your computer normally.
Feb 21, 2011 | LG Computers & Internet
Hp pavilion a305w won't boot up all the way screen
hi, for select the boot option press F8 on your keyboard.. if your computer have a problem it will pause then it will restart mybe it might have a software or memory problem.. To fix the software problem you only put your recovery disk then start recover.. if the problem still their then you have the hardware problem to fix it you must remove your old memory in the computer then buy a new one...
regards...
Mar 04, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
Aug 31, 2009 | HP Pavilion A720N PC Desktop
Victim of software Counterfeiting,Problem
To temporarily bypass the problem you can do a system restore to a date before you started having the problem.
If that does not work, boot to safe mode after downloading and installing HijackThis. Start Hijack this software (utility to modify registry values) and scroll down registry entries to the line that says “020 - Winlogon Nofity: Wgalogon - …” select it, and click fix checked.
If you think that your isystem is counterfeit and you had been victim of a scam you should contact the person that sold you the computer, and then contact Microsoft.
See Microsoft Help and Support.
Mar 08, 2009 | LG Vu CU920 Cellular Phone
On my desktop,i do get notification as "you may be a victim of software counterfeiting" and my desktop background looks black always because of this reason.. How could i get rid from this problem..
To bypass temporarily the problem you can do a system restore to a date before you started having the problem.
If that does not work, boot to safe mode after downloading and installing HijackThis. Start Hijack this software (utility to modify registry values) and scroll down registry entries to the line that says “020 - Winlogon Nofity: Wgalogon” select it, and click fix checked.
Victim of software counterfeiting
You will have to go to Microsoft.com and relicense your copy of Windows XP. You can purchase a new key and see if that will reset the desktop or wait until the CD arrives to reaload it.
Jan 28, 2009 | Microsoft Windows XP Professional for PC
My windows xp software
If you find the message :
"You may have been a victim of software coounterfeiting.
This copy of Window did not pass genuine Windows validation.
Ask for genuine microsooft software."
That means that your system is counterfeit
If the system is counterfeit I cannot help you because of Fixya policies on piracy.
If it is not, I can tell you that you can get rid of the problem doing a system restore to a date before you started getting the message.
Oct 31, 2008 | Microsoft Windows XP Professional
Desktop not appear
sounds like a bad processor board
Oct 24, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
