Question about Maytag LAT2300 Top Load Washer
Does not agitate
It does everything fine but it does not agitate, it seems
to be locking up but it does spin dry. This is a Maytag
LAT9593 is it worth fixing or not.
Thanks
Rick
  • 82 Answers
In the top of the agitator is 6 little dog ears very inexpensive and some what easy to remove your local appliance parts store should be able to show you how to replace them. just pull the agitator out and take it with you....goodluck
Posted on Jan 04, 2009
Maytag performa stops during agitate or spin
All washers have a safety switch on the on lid. There is usually a slot that a plastic pin goes into to activate the switch. These switches are high failure parts. The switch is located on the underside of the top deck. It should check 0 ohms when closed. You can also jump it but then it would NOT stop when the lid is open ie; during agitation or spin cycle ( a safety hazard).
Sep 01, 2012 | Maytag Washing Machines
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
My Maytag washing machine does not really agitate
It sounds like the belts need replaced. There are 2 of them. One drives the transmission, and one drives the belt. They should both be replaced. Also, there are rollers on the motor bracket that wear. Make sure the motor moves smoothly back and forth in the bracket.
Jan 28, 2010 | Maytag Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
Jul 11, 2009 | Maytag Dependable Care LAT9706
Agitator
A serious transmission problem, I doubt that it is worth the cost of repair, sorry.
Aug 21, 2017 | Maytag Performa PAV2200
MayTag Washing Machine
can you hear the motor running or is it humming
Mar 26, 2008 | Washing Machines
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
188 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
