Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
I am trying to plug an RCA Home Theater Sound Bar into the TV. When I plug into the RED and WHITE output I get no sound on the sound bar.
TOSHIBA 2011 42" HDTV (Model#40FT2U)
SOURCE: No sound on my toshiba television
Go to the setup menu and turn the TV speakers back on.
Posted on Feb 16, 2008
  • 7 Answers
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Posted on Sep 18, 2008
SOURCE: Is my Toshiba TV, model MW20FP1, digital?
I solved my problem by going to toshiba.com and found a list of models that ARE digital... mine is not on the list so I will get a converter box!
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: my toshiba satellite u305-s5087 model has stopped giving sound.
try to check the device manager and see if there's a driver problem, you can reinstall the driver or just reconnect the device to your unit.
Posted on Jun 12, 2009
SOURCE: Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Posted on Oct 24, 2009
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
I have just bought a samsung soundbar hw h355 and I'm trying to connect it up to my toshiba tv, via the aux cable but I get no sound from it via the tv link. I works when I link my phone up via Bluetooth....
Please get a optical cable and run it from TV to soundbar for best sound. If you are using aux input on sound bar that will work but it is analog sound. TV needs to have mini audio out or red/white output on it maybe labeled audio out
Feb 10, 2015 | Samsung Audio Players & Recorders
How to connect my tv to optical outlet
What audio-outputs does your TV have? SPDIF? 3.5 millimeter stereo-jack? White/Red RCA "post-and-collar" sockets?
What inputs does the sound bar have? (Same choices as above.)
Note that you might need a 3.5mm to stereo-RCA cable.
Feb 09, 2015 | Televison & Video
My sound bar didn't come with the red/white aux cables. I had some at home. I plugged the red into the red, and white into the white, but, it's not working. And yes, the soundbar is on. My input lis
Think you can set sound bar to play via Bluetooth .go into the settings of the tv and look for Bluetooth.when the sound bar is on make it discoverable and the tv will pick it up.if you don't have Bluetooth then check to see if there is an option switch in settings to use external speakers.check cable and also check volume on sound bar is not muted.also see if you can link the tv to sound bar via optical link cable as this is much better than RCA red/ white audios which tend to fail as people pull on the cable rather than the plugs when removing them from equipment.
Dec 12, 2014 | RCA RTS735E Home Theater Sound Bar
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Sound bar how to connect
if both have hdmi plugs just use the hdmi cable to hook it up if not then run your red and white cables from the tv to the sound bar
Jun 02, 2014 | Audio Players & Recorders
Sound bars
It has red and white RCA jacks you should be able to use as the input from your tv. Plug into audio out on tv.
Apr 14, 2014 | Panasonic SC-HTB65 Home Cinema Sound Bar...
Connecting rca sound bar to lg plasma tv
There should be a left and right audio output jack on the back or side of the plasma. Plug in the bar and should run. Some TVs, under the audio menu, have a selection category for external speakers.
Jan 19, 2013 | RCA Alco Electronics RTS635 Home Theater...
How do you connect the speakers on to your flat tv. I read it on the manual that u have to use HDMI, but i did. It still won't work.
This model has speakers. If you are trying to connect external speakers i.e. a home theater system, receiver or a sound bar you have a couple options.
This television only has hdmi inputs so you cannot connect the external speakers with hdmi cables. The television would have to have and hdmi output.
Now in order to use hdmi you would have to connect all your devices to the home theater and then go hdmi out from the home theater to one of the two hdmi inputs on this television. Then you would leave the television on that hdmi input at all times and switch devices with the home theater remote.
All the devices would be connected from their respective outputs to a respective input on the home theater.
Another option is to connect a fiber optic cable from the television to the home theater.
Another option would allow for stereo sound but not the higher quality surround sound. You can connect from your televisions red and white RCA outputs to the RCA input on the home theater.
Dec 30, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
