Question about Yard Man Garden
Need to know the proper fuel mixture for yard man 27cc ym2bp leaf blower
Model ym2bp ser# 11061df1231 item 41ar2beg901
3 Suggested Answers
SOURCE: FUEL MIXTURE
I have the manual in front of me and it says 25:1 or if you are using "castrol super tt" then 50:1
Posted on Sep 20, 2009
  • 3600 Answers
SOURCE: Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Posted on Mar 10, 2010
Testimonial: "sweet bro thanks 4 the extra tips as well"
Yard Man Leaf Blower Model YM2BP Won't Start. I recently got this back pack blower from an auction with some other items. It looks to all be there, but it seems to have low compression. I don't have a...
Brian if it's got such a low compression it's the gaskets and to be honest if they are that hard to come across don't waste your time and effort. The best thing would be cut your losses and get rid. If there are any useful parts keep them.
Oct 07, 2013 | Garden
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Rebuilt carb need air and idel mixture screw settings. Blower runs but only a few seconds and then will not restart.
air fuel mixture screw shoould have initial setting of two turns out from lightly seated,check unit make sure cylinder is tight to base they only have two screws holding them down,if 2 cycle motor has a vaccum leak they will not run properly,also check compression if you have gauge should have a least 100 psi to run properly.
Oct 01, 2009 | Homelite 'Yard Broom' Leaf Blower
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower won't stay running
Replace fuel with clean fuel with proper oil mix. Also the carb. could need cleaning or diaphragm could need replaced. One thing you would need to check that will not cost much but may save you a lot of trouble is the muffler. Check the muffler for obstructions and remove the muffler and check the exhaust port for carbon buildup.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Fuel mixture for 32 CC McCulloch leaf blower
Gas to Oil ratio is 40 to 1. (40:1)
Oct 12, 2008 | Garden
Garden Logo
184 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
