Question about Ovens
Lamona built in oven making loud noise from fan
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
SOURCE: fan assisted oven
i would suggest to renew the complete fan, but i found a company which sells lubricants that can bear tempratures of 550 degrees. follow this link: http://www.tomlinscientific.com/lubricants.html
Posted on Aug 16, 2007
barkencoa
  • 3463 Answers
SOURCE: Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Posted on Dec 02, 2009
Testimonial: "Thank you for that. It's noisy even when the fan inside the oven isn't running (ie, just on convection) so guess that means it's the external fan?"
barkencoa
  • 3463 Answers
SOURCE: My AEG competence oven is
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Posted on Dec 12, 2010
Where can i buy a new outer glass for HJA4610 Lamona as mine has exploded?
Have a look at https://www.howdens.com/appliance-collection/ovens/lamona-double-fan-oven/
Oct 07, 2016 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
I have a lamona hja3400 oven and the element has stopped working. I'm trying to get the element out but it seems to be fastened on the back of the oven not inside it as with other types of ovens. Does...
hi my lamona oven started to make a noise like a pinging noise it was working the noise would come and go it would get worse half way through cooking. but last night the noise seemed to have lasted longer and the oven knocked itself off any ideas what the problem could be.
Aug 30, 2013 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
OVEN MAKES A LOUD NOISE WHEN IT IS TURNED ON. IT SOUNDS LIKE THE FAN IS HAVING TROUBLE TURNING OR SOMETHING.
This indigates worn or tight fan motor bearings, if it is a built in oven , then it could have an external cooling fan in addition to the oven fan, so you will have to determine which one it is.
Usually it means having to replace the offending fan motor, as lubricating only provides a short term solution.
Hope this helps.
Jan 09, 2010 | Whirlpool Ovens
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Ovens Logo
1,486 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
