Question about Opella Plumbing
I have a new strainer basket but it won't seal water to wash dishes.
The basket will not seal water in sink.
  • 2712 Answers
SOURCE: Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
  • 33 Answers
SOURCE: I need a new franke
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Posted on Jun 06, 2009
SOURCE: Moen basket strainers for Corian
I'm not sure what your question is, or if you are posting information.
Plumber's putty is purchased at local home center, hardware, plumbing outlet.
Container is smaller than coffee cup, and 3 times heavier.
Material is gray and thick and slightly oily and not sticky on the fingers.
Clean sink opening.
Apply fairly thick amount of putty completely around sink opening. About 3/16" thick.
Putty should extend wide enough so sink basket sits entirely on top of putty.
Push sink basket down into putty.
Tighten sink basket very firm from below.
Wipe away excess putty inside sink bowl with finger, and then a paper towel or damp sponge.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 15, 2011
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
What is the proper way to install a BLANCO sink strainer Kitchen Sink COD.100113 I believe is the code # Thank you
Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
Feb 09, 2011 | Blanco Sink Waste Strainer / Stopper...
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
Jan 28, 2011 | Acme 6001 Juice Extractor
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Sink Basket leaks and cant be removed cause of silicon adhesive
steady pressure from under the underside of the sink should cause the silicone to flex and eventually release.
You might also try some caulking remover available ot hardware stores. It's a product that comes in a tube and eases the removal of caulking products.
Be sure to look at the label for cautions and materials that it is safe to use it on.
Oct 07, 2009 | Belle Foret BF-NBBS2-CP Junior Basket...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
Jan 28, 2009 | Plumbing
Plumbing Logo
94 people viewed this question
Top Opella Plumbing Experts
Donni Steen
Tom Chichester
Are you an Opella Plumbing Expert? Answer questions, earn points and help others
