Question about Singer Deluxe 5040 Computerized Sewing Machine
How to insert a bobbin into a singer 5040c - Singer Deluxe 5040 Computerized Sewing Machine
JeremySew
  • 65 Answers
SOURCE: Bobbin type for singer model 5040C
We have those bobbins available here:
Singer Sewing Machine Bobbins
Posted on Oct 06, 2009
SOURCE: Help with threading info for a Singer 5040c
I have the same problem. Driving me nuts. The tension dial is broken, as far as I can tell. Just craps out from time to time. Sometimes turning it on and off helps. I personally think it's a problem with the electronic controls.
Posted on Mar 01, 2010
  • 1116 Answers
SOURCE: i have a singer 5040c an sometimes the tensioner
You can get a users manual from the Singer Website for model 5040.
Thread the machine with the presser foot up and see if this helps.
Posted on Mar 15, 2010
  • 139 Answers
SOURCE: Singer machine 57815 - it looks like the bobbin is
http://www.singerco.com/resources/bobbin.html You can find step by step instructions on this webpage.
Posted on Apr 16, 2010
SOURCE: i have a singer 5040c and it won't do a zigzag
My wife just had this a similar problem with her Singer Omega 36 where she could sew straight and select patterns but could not zig zag. If you open the top of the machine you can see where a little lever connects to the white plastic pattern module that gets inserted in the top. The reason for the problem was that the lever was not touching the bottom of the module properly. The notches on the module cause the needle to move from side to side creating a zig zag. The module needs to be inserted correctly, by this I mean fully and the correct way around or it does not reach the lever when it is in the A position. At first inspection it looks the module could be inserted any way around but there is a thin and a fat clip. You need to try both ways to see which on sits lower in the machine. You may now need to adjust the tension on the machine as the lever will nowe move differently inside the machine. This fixed my wifes problem.
Posted on Jun 21, 2010
How to thread bobbin on Singer Serenade 30
The owner's manual should have instructions. Otherwise, search the internet for videos/tutorials for using your machine, ie:
Inserting the bobbin on Singer sewing machine
How to set up singer sewing machine MP4
Machines vary on how the bobbin is installed. A lot of Singers have a drop-in bobbin, but others actually have a removable bobbin case. Just search until you find one that is similar to yours.
Feb 14, 2016 | Singer Sewing Machines
Singer 301A
do you have a manual?
try a new needle
rethread the machine-presser foot in it's highest postion
make sure the bobbin is inserted correctly into the bobbin case
& that the bobbin case is inserted correctly into the machine
Jun 05, 2012 | Singer Sewing Machines
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
Dear Sir/Maam Bobbin casing on my sewing machine gets tilted and is not allowing machine to work.Motor works fine.Please help.The model # is 5040C.A prompt response is truly...
You could download an instruction manual from www.singerco.com website, link is http://www.singerco.com/accessories/manuals.html, type in your model number and press "search" to locate it.
The manual should assist you in troubleshooting the problem, it sounds like the bobbin case is either incorrectly inserted or faulty but go through the threading diagrams and see if this helps you to resolve it.
May 23, 2011 | Singer 5050 Mechanical Sewing Machine
Threading up a bobbin in a singer 560 sewing machine
I'm guessing it's probably the same as mine (8280). This is what the manual says: "Hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Pull the thread through the **** and under the finger. Hold the bobbin case by the hinged latch and insert into the shuttle." It's hard to describe, but if you've sewn before, it should come back quickly. To be more specific, hold the bobbin case in your left hand, insert the bobbin so the thread is coming up from underneath, pull thread through the **** and into the part where the hole is. If you slide the thread around, it will fit into the slot in there. Pull the latch out and insert it into the shuttle.
Hope this helps.
Mar 27, 2010 | Singer Sewing Machines
I have a singer 5040c an sometimes the tensioner
Mar 15, 2010 | Singer 5050 Mechanical Sewing Machine
Mar 04, 2009 | Singer 5050 Mechanical Sewing Machine
Singer Deluxe 5040 Computerized Sewing Machine Logo
21 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
