Question about Dacor Preference RSD30 Gas Kitchen Range
Does the Dacor rsd30 have an internal circuit breaker?
Heating elements top and bottom quit working after oven left on for 30 min with door open.
  • 163 Answers
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Posted on Jan 04, 2009
  • sitano Mar 08, 2014
    I have a RSD30B, where is this switch located?
    New Friend:
I have replaced all fuses, however still all internal lights, radio, range hood not working on 12 volts, cannot find the circuit breaker all I can find is circuit breaker for 240 volt system on coromal seeka 475 pop top
Posted on May 12, 2013
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Lower oven element won't heat
check the oven compartment sensor that actuating the oven temperature
Apr 26, 2012 | Dacor Preference RSD30 Gas Kitchen Range
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
Jun 23, 2010 | Kitchen Ranges
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 | Ovens
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Rsd 30
I believe I followed the post by Rotu on11/11/06--remove the black grill surrounding the oven door latch (it's held on by 4 black phillips-head screws about 3" on either side of the latch). I had to use a flashlight to see into the space (there are a bunch of wires as I recall). In the middle several inches back you will see a small (about 3/8") red (mine had darkened) button. We used a screwdriver (be sure your circuit breaker is OFF) to reach it and push it down to reset. Replace the grill, turn on the breaker and you are good to go.
Dec 20, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Nov 21, 2007 | Dacor ECD230 Epicure Electric Double Oven
Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
Nov 01, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
591 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
