Question about JVC AV-27530 27" TV
Cannot get 27" jvc av-27530 tv to recognize playstation 2
I connect everything through video 1 with no success. Do the same through video 3 and no success either. i believe it worked before but cannot remember for sure. moved tv to another room recently and cannot get it to recognize playstation 2 anymore. any thoughts?
  • bssalamon Jan 11, 2009
    Thanks for your help. I figured it out. I had a bad Playstation audio/video cord. Thanks.
  • 81 Answers
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
Posted on Jan 04, 2009
My tv jvc av 27530 has ablue screen and un able to operate by remote or manually so could you help me please?
many of the late model tvs with a crt (picture tube) would go to a blue screen when there is not signal from the cable or antenna so you don't get the irritating white noise and black and white dots running all over the screen, (called the raster), so probably you aren't getting a signal to the tuner. check your connection from the cable/antenna.
Sep 25, 2014 | JVC AV-27530 27" TV
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
SD TECH
Aug 09, 2010 | JVC AV-27530 27" TV
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
I have a JVC television that has a vid 1 and vid 2 input slots. vid 1 is ran to my dvr, but vid 2 will not recogonize my playstation or my dvr. so i have lost the ability to play games on this tv. any...
I do not have that particular TV so I cannot be overly specific, but you should look for the menu option. There should to be a selection where you can enable your Video 2 input.
Mar 07, 2009 | JVC AV-27530 27" TV
TV Value
under $100.00
Aug 04, 2008 | JVC AV-27530 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Jvc tv does not recognize toshiba dvd player sometimes....
Which cable type are you using (component, composite, HDMI...)? If it's composite (the white, red, yellow) it may be in "progressive scan" mode. Check the manual to see how to toggle betwixt the two.
Sep 10, 2007 | JVC AV-27530 27" TV
JVC AV-27530 27" TV Logo
144 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
