Question about Kenwood Food Mixers
My kenwood hand mixer stopped working after overheating
Overheat
3 Suggested Answers
  • 832 Answers
SOURCE: i have brown hand mixer . hand mixer's switch is
Just buy the replacement switch, buy a star or philips
screw driver and do it yourself. Just copy how it is mounted and get it done. Just e-mail to us the result.
Posted on Oct 05, 2009
KevinWhite
  • 1902 Answers
SOURCE: Kitchenaid Mixer stopped working checked power
Hello & Welcome to FixYa
I believe the motor is bad and needs replacement...Motor brushes goes bad after sometime and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jan 16, 2011
Repair Hand Mixer
the head gears are not engaging properly
could be the selector knob or stripped gears
get a quote from an appliance repair shop but if the mixer has a few years on ti then it will probably turn out cheaper to get a new one
Feb 25, 2016 | Kenwood Food Mixers
Kenwood HM320 Hand White 250 Watts Mixer
could be the result of a bad bearing,either that or something has caused the offbalance of the rotor.it should be repairable,if you take it to some repair workshop,unless you would want to take it apart yourself.
Apr 21, 2012 | Kenwood HM320 Hand White 250 Watts Mixer
Ibought a hobart n 50 mixer took it oversaes used a 700 watt step down transformer to work it but after a few minutes it over heats is there a certain trans former to be used for it thank you
Assuming the mixer is overheating (and not the transformer), first check (with a multimeter) the voltage being supplied to the mixer from the transformer and ensure it is near 120V. Next, do you know the powerline frequency in the country you're in? The mixer (assuming it came from US) was designed for 60Hz US power. Many other countries use 50Hz, which could cause overheating if the mixer is used heavily. When 60Hz equipment is used on 50Hz power, it normally must be "derated" meaning it must be "underworked" as compared to its original capabilities.
Be sure to test the voltage going to the mixer, from the transformer, not only when the mixer is off, but be certain to test it in use, mixing whatever it is you are mixing -bottom line is to be sure the transformer continues to output 120V under load, with the mixer loading the transformer.
If all is OK with the power going to the mixer, then the problem is either in the mixer or the problem is how it is being used. What are you mixing with it - are you overworking the mixer? Does the mixer always overheat or only with particularly demanding jobs (cut down batch size in this case). What gear are you mixing in? If overheating in second gear, try mixing the same batch in first gear. If you have or can find a user's manual, it probably gives reccommended batch sizes for various typical products you might mix, be sure to follow these recommendations and "derate" for 50Hz if necessary.
It's possible the motor is weak from a long life spent working hard. A weak motor will draw excessive current and overheat. Where is the mixer hottest? The front at the gearbox/transmission or the rear where the motor is located? Maybe the transmission is lacking lubracation and needs a grease change. There a many possibilities for your mixer to overheat, and I hope this helps.
Nov 20, 2010 | Hobart N50 Stand Mixer
Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
Jul 29, 2009 | Kenwood Food Mixers
Kenwood Chef A702 mixer stopped running
You should sell it for parts on eBay. You may not get much, but anyone willing to pay for shipping will appreciate whatever parts are still working.
Apr 10, 2009 | Kenwood Food Mixers
Food Mixers Logo
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
