Question about Refrigerators
What are the dimensions of my refrigerator model # et18pkxpnr1 serial # e62623788
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
I need exterior dimensions of old Kenmore side by side model 10656234000
Dimensions for a 17cft model!
Dimensions and Capacity:
Depth w/ Handle (In.): --------- 30.375
Depth w/out Handle (In.):------ 30.375
Height to Top of Case (In.): -- 67.375
Height to Top of Hinge (In.): -- 68
Width w/ Door Closed: --------- 28
Jul 23, 2016 | Kenmore Refrigerators
What are the Dimensions.
Refrigerators might have quite different dimensions. You can ask at "Contact" in website of any retails store, home depot or similar site, indicating the model and brand or, you even might specificate the dimensions you'd like and they might provide you a lisiting with brands and models available. FIXYA is actually a Q/A site where people like you and me answer questions made by people like you and me, to solve doubts and problems.
Apr 21, 2015 | Refrigerators
Ariston instruction manual
A bit hard to come up with dimensions or user instruction manual without knowing the refrigerator type or model number.
Please visit this Aristron website and select the model number listed to download the user manual or check the dimensions. Cooking Appliances Kitchen Appliances Dishwashers Download Manuals
Aug 29, 2014 | Refrigerators
Just want to know the size so i can replace it
Just measure the outside height, depth and width. A replacement of the same or bigger dimensions will hold as much or more stock
Apr 27, 2014 | Roper RS22AQXKQ Side by Side Refrigerator
What are the dimensions for a Whirlpool Refrigerator ED22DQ?
A complete model number is needed, here is a list of manuals from Whirlpool.
Manuals and Literature
Apr 11, 2014 | Whirlpool Refrigerators
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
orders@coolergaskets.com
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
