I needdriver wintv-hvr-1800 for windows 8 - Televison & Video
bhiga
  • 119 Answers
SOURCE: No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Posted on Apr 30, 2008
SOURCE: Hauppauge WinTV HVR-1600 - ATSC HDTV receiver
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Posted on Nov 02, 2008
SOURCE: WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Posted on Feb 28, 2009
  • 617 Answers
SOURCE: WinTV HVR-1600 not working when I upgraded from Vista to Win 7
get drivers for win 7 for card
Posted on Feb 05, 2010
  • 92 Answers
SOURCE: Dell? Hauppauge WinTV-HVR-1250 TV Tuner
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
Posted on Feb 07, 2010
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
AV input selection on WinTV-HVR-1200 card
no you have to have a video card installed that provides output features. the tuner card will provide the input feateres..
Oct 15, 2009 | Dell Computers & Internet
Compatibility of vista os with hvr-1100
yes it is,
Supported OS: Windows XP Windows XP MCE Windows Vista Windows Vista MCE
Jun 22, 2009 | Hauppauge WinTV-GO PLUS PCI TV Tuner...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Problem installing WinTV HVR 1600
It just means that it is not not registered to work with windows by microsoft.
The manufacturer doesnt have to work with Microsoft to make their products work.
If possible you can go ahead with the installation. To be safe set a restore point before doing so, though
Jan 12, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
TV Tuner for my HP
Hello Matt,
WISH YOU HAPPY MERRY CHIRSTMAS!!!!!!!!
I am Vikram Kumar Thumu from India- Hyderabad. I have seen your message on the issue related to the Tv Tuner card. Since, I work with HP as Technical Support I would like to suggest you on this issue.
Well, the "HP ExpressCard TV Tuner for Windows Vista
(RM436AA#ABA)" supports only for Windows Vista.... and it will not work with Windows XP.
If you are lookng for Windows XP Tv Tuner Card, I recommend you to purchase Hauppauge WinTV-PVR USB2 (EC557AA#ABA). As this one supports for Windows XP but needs Microsoft Windows XP Media Center Edition 2005 .
These are available solution for you at this moment . I hope that this should resolve the issue for you.
If you need any other information please do mail me at thumuvikram@rediffmail.com. I'll be glad to help you.
Once again WISH YOU HAPPY MERRY CHRISTMAS!!!!!!!!!!
Thanks,
Bye...
Dec 26, 2007 | HP Expresscard TV Tuner For Windows Vista...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
