Question about Canopus ADVC-110 (77010150100) Video Capture
CANOPUS ADVC110 AUDIO PROBLEM MY PROBLEM WITH THE AUDIO IS WHEN PUT RCA MONITOR THE AUDIO COME BAD.
  • molecule18 Dec 18, 2008
    the audio doesn't work at all
    Scholar:
  • 119 Answers
Does the audio play back OK on the computer? Sounds like the audio level is incorrect.
Make sure you connect the audio output to a Line input, not a Headphone or Phono input.
Posted on Apr 05, 2008
SOURCE:
How do I take video tapes media from a sony handycam ccdtrv81 and load it into imovie to make a montage with my own old home movies?
Hi Vicki
You are not going to do it without spending some money.
Look on ebay for something like a Canopus ADVC110. It's good quality (sorry - excellent quality) unit powered from your Firewire socket. It does Analogue-Digital conversion both ways. Into iMovie and then back out to your camera. in fact iMovie sees it as your camera. You can find cheaper kit but the picture quality is not as good. There is a more expensive version that has video noise reduction built in but it's best use is for removing noise from VHS tapes when importing to iMovie.
There are several on ebay in the UK right now. Canopus is now called Grass Valley - one of the biggest manufacturers in the broadcast TV world.
Nov 29, 2009 | Sony Handycam CCD-TRV81 Camcorder
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
Canopus ADVC110
Yes you can. I have that very same setup using a surveilance cam as my webcam =)
Yawcam is a pretty good allround webcam application with lots of features, I recommend it!
Sep 29, 2008 | Canopus ADVC-110 (77010150100) Video...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
ADVC110 - not recognised by computer
If you're using the AC adapter, try it without (using a 6-pin to 6-pin Firewire cable) the AC adapter.
Otherwise try a different Firewire cable.
Jun 23, 2008 | Canopus ADVC-110 A/D Converter...
PAL Problem and ADVC110
It's difficult to tell what's really going on by looking at the PC monitor. You should generate a DV file and play it back through the ADVC to a TV and see.
The issue is interlacing. Since the two fields of interlaced video are originated at different points in time, when you play both fields on a non-interlaced display like a PC monitor, you see the two combined and they don't match up. So you get half of a ball before the line, and half of the ball after the line and it looks funny.
Apr 17, 2008 | Canopus ADVC-110 A/D Converter...
ADVC110
I'm guessing that you have it connected via a 6pin firewire on the ADVC100 to a 4pin firewire on your macpro. The device needs to be connected via 6pin to 6pin in order for the device to get power, otherwise you'll have to buy a AC adapter (which is not included). Otherwise it's a great device for DV conversion on multiple platforms!
Mar 23, 2007 | Canopus ADVC-110 (77010150100) Video...
Canopus ADVC-110 (77010150100) Video Capture Logo
300 people viewed this question
Top Canopus Televison & Video Experts
Archie Ferrarini
Archie Ferrarini
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
