Question about Maytag HYE3657A Electric Dryer
Kenmore dryer electric doesnt start
I press the start button and all i get is a simple one click and nothing happens. i checked power to start, door, etc. i think it is a bad switch?Power does go to the start button,
  • 148 Answers
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Posted on Jan 04, 2009
Hi,I have a Kenmore Elite HE3 electric dryer which is only about 3 months and the problem is that when I press the power button, nothing happens, even though the dryer IS connected to electricity beacause...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Oct 20, 2010 | Kenmore 82822 Electric Dryer
Our dryer stopped working in the middle of a load. Now when I press the start button the timer does nothing but click. I am not sure but I thought it might be the push start button was faulty. Any ideas?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | Kenmore 64892 Electric Dryer
Dryer has power but nothing happens when you press the start button.
First check the door switch to make sure it is clicking when depressed. Open door and depress the door switch with your finger, should hear a click. If you do not replace the door switch. Other problem will be the thermal fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps.
Mar 09, 2010 | Whirlpool GEQ9800L Electric Dryer
Dryer does not start
Aug 20, 2009 | Dryers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Doesn't work at all
Check the door switch. With the door open, on the upper right side of the tub opening there should be a little lever. Push on it and you should hear a click sound. If the lever is broken or no click sound, you need to replace the switch. If that checks good check your circuit breakers and power cord and outlet.
Apr 08, 2008 | Kenmore 63032 Electric Dryer
Maytag HYE3657A Electric Dryer Logo
182 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
