Question about Honeywell MS9520 Voyager - Barcode scanner - portable - 72 scan / sec - decoded - keyboard wedge Handheld Barcode Scanner
How to use Honeywell MS9520 Voyager Barcode scanner as an input device into Excel
I have a Honeywell Voyager MS9520-41-3 with an RS232 cable end which when plugged into the Sam4s cash register works beautifully. However I also want to use it as an input device for stocktaking purposes by scanning a barcode and typing in the number in stock. There are 4 or 5 drivers on the Honeywell site and I'm not sure which one is relevant to my Windows Xp system. Do I need a keyboard wedge or a usb cable instead of the one fitted? If I plug it directly into the back of the computer, it is not detected as an uninstalled piece of equipment. Can anyone help?
3 Suggested Answers
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
  • 55 Answers
SOURCE: I want scan barcode 39. Hou
http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
Posted on May 26, 2011
Why cant I get my computer to accept it
you might have to set up the serial port settings with speed (baud rate) number of stop bits, even or odd parity. suggest google how to set up serial port on whatever operating system you have. does the p.c even have an rs232 port may need a usb to rs232 adapter device.
Apr 20, 2015 | Honeywell MS5145 Eclipse with Codegate...
How i can configurate ms9520 by rs232 which command can i use
Scanners are programmed by printing the barcode & then scanning with them. For this one, go to https://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
print it & scan the relevant barcode.
Dec 16, 2014 | Microsoft Metrologic MS9520 Voyager...
MS9520
Please Reset the Scanner. Manual has the Reset Bar Code
Feb 14, 2014 | Honeywell MS9520 Voyager Handheld Scanner...
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Driver for Honeywell MS9520
Yo! I will have to direct you to a website where you can download anything for your computer. please follow the links below..
www.download.com
http://www.filehippo.com/
Aug 13, 2011 | Metrologic Instruments HoneywellMetrologic...
I want scan barcode 39. Hou can i program mine ms9520 voyager scanner. Thank you
May 26, 2011 | Honeywell MS9520
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Honeywell MS9520 Voyager - Barcode scanner - portable - 72 scan / sec - decoded - keyboard wedge Handheld Barcode Scanner Logo
97 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
