Remote Desktop Connection Not Connecting
In the built-in Remote Desktop Connection Software in Windows XP Professional, I used to be able to connect to remote computers on my LAN.  There is one computer that I mainly connected to.  It is my Dell Dimension 2400.  I have a slow laptop that I use as a window to use my Dell.  It would connect fine before but now it wont.  When it is trying to connect, the close button turns to a cancel button.  Then, after about one second, the button switches back to a Close button with the password field cleared.  It acts like when you get an error message, except there is no error message.  Help please!  I have searched on two other forums and still can't find an answer!  Thanks!
  • techguywill Jan 04, 2009
    I looked but the IP Address did not change on either computers. I tried re-entering the info but to no avail. I know that it is not my laptop because I can't access it on any computer on the LAN.
  • 31 Answers
The IP Address (local) may have changed. Go to the computer you are having problems connecting to, and into cmd.exe and type :
ipconfig /all
Then try that IP you get from ipconfig
Posted on Jan 04, 2009
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
XP/SP3 LAN icon missing. No internet connection
Click Start
Click Control Panel
Click Classic View
Click Network Connections
Is your LAN adapter listed?
Do you have a laptop with a built-in Ethernet adapter?
Do you have a desktop with an add-on PCI Ethernet card?
Aug 19, 2010 | Microsoft Windows XP Professional
How do I setup Remote Desktop Service
I assume that the the computer on which you want the Remote desktop and the target computer whose desktop you want to capture are networked properly and the IP address with other TCP/IP settings are properly configured.
That said Go to Start and click Run the Run box will appear. In the run box type "mstsc" command to connect. A box will pop up asking for the "Computer" enter the computer name or more preferably the IP address which you want to connect to and capture the desktop remotely the Target computer.
Go to the target computer physically and right click the "My Computer" icon and then in the menu select the properties tab and click it you will see "System Properties" window pop up. On the top you will see some tabs. Select and click the "Remote" tab. At the Remote Desktop make sure that the "Allow users to connect remotely to this computer" check mark is selected if it is not ticked tick it. This is the way you are allowing your computer and other computers on the network to connect to this target computer.
Now go back to your computer click the connect tab.It should always connect as long as you give the correct IP or computer name in the "Remote desktop connection" box.
Best of Luck!!!
Jul 30, 2010 | Microsoft Windows XP Professional for PC
What are the common operations of windows xp?
Operations of Windows Xp.
More stable and secure than previous version.contain remote
desktop connection and restore option if crash etc.
Built on the new Windows engine
Enhanced device driver verifier
Dramatically reduced reboot scenarios
Improved code protection
Side-by-side DLL support
Windows File Protection
Windows Installer
Enhanced software restriction policies
Preemptive multitasking architecture
Scalable memory and processor support
Encrypting File System (EFS) with multi-user support
IP Security (IPSec)
Kerberos support
Smart card support
Internet Explorer Add-on Manager
Windows Firewall
Windows Security Center
Attachment Manager
Data Execution Prevention
Windows Firewall Exception List
Windows Firewall Application and Port Restrictions
Fresh visual design
Fresh visual design
etc.....
features of windows xp:
1.Ntfs file system supporting.
2.remot desktop feature supported.
3.internet explore version 6.0.
4.Bluetooth 2.0 Update
5.inbilt firewall.
6.Internet Connection Firewall.
7.Recovery Console
8.System Restore
9.Peer-to-peer networking support
Again,
1. Instant Messaging.
2. system restore.
3. Ntfs file system supporting.
4. Remote Desktop.
5. Firewall Inbuilt
6. ASR available
7. EFS available
8. Fast User Switching
9. Point to point Networking support
10.Fast user switching
11.Windows security center
12.Recovery Console
remote assistance
remote desktop
firewall
hibernate
rollback drivers
inbuilt cd burning wizard
fast user switching........
Jun 23, 2010 | Microsoft Windows XP Professional
Where is the remote desktop menu?
in control panel. why are you still using xp?? get 7 its alot better then any of microsofts os's!!!! hope helps :D
Feb 13, 2010 | Microsoft Windows XP Professional Remote...
Remote Login Failure
This message means that the user account you are trying to use does not have rights to log on remotely. You need to go to the server, log on as an administrator at the console. Once logged in, add the user account you want to use to the local "Remote Desktop Users" group.
Jun 17, 2008 | Microsoft Windows XP Professional With...
How can i adjust remote desktop connection
http://www.microsoft.com/windowsxp/using/mobility/getstarted/remoteintro.mspx
http://www.windowsnetworking.com/articles_tutorials/Using-Remote-Desktop-Windows-XP-Pro.html
Jun 07, 2008 | Microsoft Windows XP Professional With...
It sounds like you had a pre-release version of RDC 6.1 installed which you should have uninstalled before installing SP3.
Check this out - under "Remote Desktop Connection" you might find the solution you're looking for.
http://download.microsoft.com/download/c/d/8/cd8cc719-7d5a-40d3-a802-e4057aa8c631/relnotes.htm
Hope this helps! : )
Jun 03, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
