Diamond One-touch video capture audio doesn't work with s-video
I have one-touch video capture from diamond and the composite works fine with my vcr but the s-video won't capture the audio from my hi-8 camcorder. any ideas?
  • Anonymous Jan 16, 2009
    Can either one of you tell me where to exactly hook up the audio jack to the PC? I just purchased this last week to do the EXACT same thing with my Hi8 Tapes.
    Any help would be much appreciated!
I had the same problem.  it turns out the s-video does not carry audio so you have to hook up a separate audio line.  On my camera there is a mini plug a/v i run a mini plug out to a rca jack splitter and then run rca cords to the red and white jacks on the one touch....then it works great.
Posted on Jan 05, 2009
Diamond VC500 no video formats and black screen, not recording
Had this exact same issue, tried uninstalling, reinstalling, unplugging, plugging back in, updating drivers, etc. with no success, but it was all resolved instantly when I switched the device to a different USB port. The port I was using before works fine (in fact my keyboard is now connected to it as I type) but maybe it is a different type of USB port, and not the one the video capture device is looking for. Hope this helps others with the same issue.
Jan 08, 2012 | Diamond Multimedia ( VC500) Video Capture
Why cant i upload my diamond one touch capture card to youtube pleeese help
Youtube, by default supports major video formats like MPG, AVI, MOV, WMV etc. If you are trying to load the .VOB files it may not support.
Try converting your videos to Youtube acceptable formats (mpg, avi, mov or wmv) and try uploading again. Also remember the maximum playback length of your videos shall be 15mins only.
Mar 05, 2011 | Diamond Multimedia Diamond VC600 One Touch...
When I capture old VCR casettes using One-Touch VC500 and Corel VideoStudio Pro X3, I get the video fine, but it pulls the audio from my headset mic rather than from the vcr. How do I force it to get the...
Somehow, you have made your System Audio Output {Jack} the Primary source of the System's Audio. You are using Digital & Analog Audio at the same time. In Modern Electronics, you have to make one or the other the ONLY source of the System sound! I wish I could see your Set-Up because I know I'd spot the problem instantly. Your solution is most likely reading Your User's Guide very carefully, and finding the Switch Setting that is designed to make it work properly. This should not be happening -- most likely you just have a Function Set incorrectly.
Dec 11, 2017 | Diamond Multimedia ( VC500) Video Capture
I just received the Diamond VC600 video capture device...but noticed it is compatible with Windows Vista. Before opening the package, what about Windows 7? Will I need to download additional drivers, or...
I have not had problems using the VC600 with Windows 7 32-bit or 7 64-bit. If you have problems installing the drivers for the device, either have windows search for updates or install the drivers manually within Device Manager by doing an Update Software on the unknown devices and use the XP 64-bit drivers on the disc. If you still have problems with the device, I would contact the manufacturer's Technical Support center to see if they can help you out with the install.
Nov 14, 2010 | Diamond Multimedia Diamond VC600 One Touch...
I have no sound with a VCR tape to DVD transfer using the Diamond vc500 - using Windows Vista - video is fine
open goole home page download Driver magician instal after update serch all drives click driver opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 28, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
I am using the vc500 to capture video. It works except
That is a frequent 'fault' with the low cost capture units.q Nothing can be done, other than seeing if Diamond has a newer driver that corrects it.
Jan 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Aug 26, 2008 | Diamond Multimedia ( VC500) Video Capture
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
