Question about Genie Company Home Security
NED 8700 smart button location
I'm trying to program the remote door opener in my GMC but cannot locate the Smart button on the NED 8700 garage door opener? I believe this is a rolling code transmitter as I cannot locate any DIP switches, is this cocrrect?
A marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
Posted on Feb 11, 2013
3 Suggested Answers
  • 3197 Answers
SOURCE: I am trying to install
If you held the smart button in too long it erases the memory and none of the remotes will work. To program it press and hold the button on your remote and then press and immediately release the smart button.
Posted on Feb 14, 2011
  • 3197 Answers
SOURCE: Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Posted on Sep 16, 2009
Testimonial: "Thank you. So does that mean I have to replace my receiver?"
Remote no longer works for craftsman opener model #139.53674SRT1 and don't have manual to figure out how to reprogram it.
First make sure the battery is good. Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote and then press and immediately release the smart/learn button. If the remote still works it will be programmed.
Aug 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to program the remote control door openers Liftmaster 3750E-1?
Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote while you press and immediately release the smart.learn button. Do this for each remote.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I program a remote garage door opener for a Crafstman 139.53615SR?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Hold down the button on the remote while you press and release the smart/learn button. If everything is working and it is the right remote for the opener it will be programmed.
Aug 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Please,help me to program my garage remots so I can open the garage door without getting out of the car. Thanks
To program you need to locate the smart/learn button which is on the rear of the motor unit near where all those white wires go. Hold down the button on your remote and then press and release the smart/learn button. Do this for each remote.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have model 139.53671 SRT gagrage door opener
If that is the right remote for the opener you need to locate the smart/learn button which is on the rear of your opener near where all those white wires go. Hold the button down on the remote and then press and immediately release the smart/learn button. It should now be programmed.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I NEED TO PROGRAM MY LIFTMASTER GARAGE DOOR OPENERS TO WORK WITH MY LIFTMASTER 1045-6 OPENER
If you have the correct remotes for your opener you can program them like this:
Locate the smart/learn button on the back of the motor unit. Press and hold the button on your remote while you press and immediately release the smart/learn button. Do this for each remote.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Re-program Chamberlain garage door openere.
Try programming your opener this way. Locate the smart/learn button which is just to the left of all those white wires. Press and hold the button on your remote while you press and immediately release the smart/learn button. Do this for each remote. Do not hold the smart/learn button in as it will erase the memory and your remotes will not work.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to reset my garage door opener
You will have to erase the memory which means you will have to reprogram your remotes and keypad if you have one.
To do this locate the smart/learn button on your motor unit just to the left of all those white wires. Press and hold this for about 6 seconds. The only thing that should work is your wall control.
To program your remotes press the button on the remote and then press and immediately release the smart/learn button. Do this for each remote you have.
To program a keypad press and immediately release the smart/learn button, walk to your keypad and key in your 4 digit PIN and press enter.
You should be good to go.
Aug 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
1,398 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
