Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WF560 wont spin - Hotpoint Aquarius WD640 Front Load Washer/Dryer
barkencoa
  • 3463 Answers
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
SOURCE: hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Posted on Sep 30, 2009
beltronic205
  • 1474 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
  • 1527 Answers
SOURCE: Hi we have a hotpoint aquarius extar 1300 spin
hello is it pumping out water if not check the pump for blockages it has to pump water out first then it should go into spin cycle. if does pump water out and still not spinning then there could be a problem with the module board this control the motor speeds hope it helps
regards
shaun
Posted on Mar 05, 2011
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hi we have a hotpoint aquarius extar 1300 spin wma46 that wont spin at all even with no clothes in ?
regards
shaun
Mar 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF560 1600 Spin Problem
i have a aquarios wf560 machine dose anyone know where the filter is
Sep 28, 2008 | Washing Machines
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
