Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
How do you remove a jenn air wall oven door - Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
  • 1314 Answers
SOURCE: Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Posted on Dec 29, 2007
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
SOURCE: Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
I had this problem and it was fixed under waranty. The was a recall on the hinges and a repair kit was provided under waranty. My ove model is jjw9630cab
Posted on Oct 04, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Posted on Jun 15, 2009
Oven door falls
jenn air wall oven
dont like the design of the hinge itself
door section has to be locked in ..
but by the design of the door capture sure looks like
the door can be removed for easier cleaning
Jun 18, 2016 | Jenn-Air Ovens
How do i remove a jenn-air built in wall oven? (older oven model W131B)
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SCREWS FROM THE SIDE OF THE OVEN INTO THE CABINETS THERE COULD BE MORE THEN SIX
Mar 07, 2010 | Jenn-Air JJW8330D Electric Single Oven
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
15 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
