Question about Ovens
How to fix a thermocouple in a beko dg582 s oven?
2 Suggested Answers
SOURCE: I have a BEko 'Leisure alta AL6ND' oven. The
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Posted on Mar 18, 2010
Testimonial: "Pretty much spot on. Thanks. "
Hi my beko alta al6cdw cooker isn't getting hot the fan is working and its warm but not hot
assuming its the oven. check element or the thermocouple
Mar 23, 2015 | Ovens
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jul 06, 2013 | Ovens
My beko oven is leaking steam from underneath. What could the problem be.
There is no solution it's a design fault with the lower oven seal not being fixed all the way round. Beko will fob you off telling you to tip the oven back this won't work either my landlord has had buy us a new oven due to it being a cheap oven and beko washing there hands of it and not wanting admit faulty products
Jul 05, 2011 | Ovens
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
Oct 04, 2010 | TurboChef TORNADO Electric Oven
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
Dec 01, 2009 | Ovens
Morning I need help please regarding my gas oven (Beko SCG7530). The problem is when i turn the gas knob on,(push and hold for say 10 secs)the oven works fine,but as soon as the knob is released the gas...
Sugar,
Sometimes it takes a minute or longer for the thermocouple to get hot enough to send the correct voltage to the main part of the gas valve to get it open & the burners to light. If after a few attempts of turning the pilot knob to off, waiting a couple of minutes and then going thru the lighting process, your problem is the thermocouple. Most repair companies will NOT install YOUR parts because of the liability & warranty issue. The best bet is to call a repair co & explain what the problem is & tell them to bring a thermocouple with them. Sears or calling your local BBB is your best course.
Jul 09, 2009 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Ovens Logo
120 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
