I have a ge washer that only has a low pichted sound. it will not turn on to run as expected. i need your help.
This washer is several years old an has not been used.i do not know whether is was running are not. it looks pretty good and i believe with a little work it will be a good washer. im thinking the capacitor is malfuctioning. it has these # on the capactior:24db450b250pa:25o cac:123c8355p006: and wgse3100a2ww. any help will be appreciated.
catriver
  • 878 Answers
SOURCE: GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Posted on Jan 13, 2007
Slinteriors
  • 8617 Answers
SOURCE: Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Posted on Feb 03, 2008
philbran
  • 242 Answers
SOURCE: Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Posted on Jan 07, 2009
buckeruu
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Posted on Jun 18, 2009
maintenacemi
  • 95 Answers
SOURCE: Six year old Whirlpool 3357978 washer stops spinning violently
the bowden cable requires adjusting like the brakes on a push bike
Posted on Nov 18, 2009
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
GE Harmony Washer- Error code- The motor is not rotating properly??
filter*** circuit = house circuit breaker or ???
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Dec 12, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
No water
Check that the screen has not become clogged.....The screen is located inside the water jacket.
Oct 26, 2007 | GE WBSR3140DW Top Load Washer
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Spins in low gear doesn't shift clothes damp
I supose you can repair it but GE does not sell parts for it so replacing it is the best way to go. This page will help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Dec 29, 2006 | GE WJSR4160D Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
