Question about Saeco Coffee Makers & Espresso Machines
My Saeco xsmall plus espresso machine is flashing red light on it
I pulled the water resevoir out by mistake too soon and now the red light keeps flashing and it won't brew coffee
    New Friend:
Owning this machine for nearly five years, all I can say is that it is an example of problematic engineering. It does not except dark roast some of the time, and if it is very well roasted it won't accept it at all. As the machine is fully automatic, there is not much you can do but roast the coffee to a degree that will be accepted by the machine. IMHO this is an unacceptable decision made by engineers and Saeco should address this issue.
Posted on Apr 08, 2015
  • 40 Answers
SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
CMV9
  • 594 Answers
SOURCE: cuisinart EM-200 espresso machine won't make coffee
you might check the water hose and make sure that it didn't come disconected. sometime they wear out over time and strech becoming loos. and when that happens the maker can not **** the water through the tube into the expressor mix causeing it to make u sucking noise.
Posted on Aug 01, 2008
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
  • 1089 Answers
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Posted on Jan 09, 2010
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
My saeco odea giro coffee machine has a red light flashing quickly. The light looks like an exclamation mark. No matter what we have done to try and correct it still doesn't stop.
First try to prime the machine.
Turn on hot water and prime about 100 ml hot water. If the red light remain you have to change the flowmeter.
Nov 01, 2017 | Saeco Coffee Makers & Espresso Machines
My saeco xsmall has red light continuously on after rinsing
You have to turn the button to the side where is the icon of the cup.
Then you have to wait until the machine stops running water by itself.
Jun 28, 2014 | Saeco Xsmall Superautomatic Espresso...
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Hi, I have a Saeco Talea Giro Plus machine and have only used it a few times. Now the alarm light is permanently on, but the machine has enough coffee and water and the drip tray and dregdrawer are empty....
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Jul 03, 2010 | Saeco Talea Giro Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Coffee Makers & Espresso Machines Logo
1,695 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
