When taking apart the Freznel screen of my C220 to clean it three small silver metal washers droppedout, but when replacing everything I was unsure of the correct positioning of three small metal washers, and two black cardboard spacers, one spacer is slightly thicker than the other.The spacers fit under the Mamyia logo and level out the focusing screen. Is an exploded diagram available to clarify exactly where they fit?.
Many thanks
Kridon Panteli
Those are spacers for equal plane for all corners.
Without the service manual, then you are up the river without ...
Just try to put spacer(s) on one side more than the other and close it up. Now look thru the viewfinder with lenses attached and check for sharpness.
If you're doing lots of cloe-up or macro, then those spacers are needed. If you can't correct problem, just shoot at F5.6 or higher.
You will have to remove or add spacer(s) by using T & E methods.
eltroman
[email protected]
Many Thanks for your reply
K.Panteli
