Question about Panasonic AG-1980 S-VHS VCR
No Power The display began "sputtering" out. Now there is no power whatsoever. If I unplug the unit, then plug it back in, the power indicator comes on briefly, then goes off and the unit will not power up. I took the cover off to see if there were any fuses - it appeared there were two on the power supply, but both looked good. Any ideas? Perhaps a bad power supply? Thanks in advance!
    Novelist:
    Champion:
  • 275 Answers
Good suggestions by Dodgecharger. I generally do not spend time locating faulty Electrolytics!! Blindly change all Electrolytic Capacitors at one shot. In India, the cost for all the 10-12 Electrolytic Capacitors in a VCR Power supply would not go beyond Rs. 150 (Approx. US$4)and the job is over in half an hour. Works 9 times out of ten for the symptoms mentioned by GoBotDotCOM
Posted on May 22, 2007
    Novelist:
    Champion:
  • 254 Answers
Power supply problems are a good possibility. If you have a DC voltmeter, you could check the outputs. In standby mode, you should see at least a +5 volt supply. This standby line is necessary to power the logic circuitry, particularly the microprocessor. In the full on mode (VCR power on), other voltages should be present in addition to the +5. You should see a +12-14 volt, (powers the capstan, video drum, & other motors if present, & possibly a supply for the LCD display of somewhere around -35 volts. A common cause for a non-working power supply in early VCRS ('80s & early '90s), such as Panasonic manufactured rigs, is defective electrolytic capacitors used to filter the above noted supplies, especially the in the +5 & +12 volt lines. Sometimes a capacitor in the primary side of the supply will go bad, causing the dead symptom. Obviously, a schematic is beneficial especially if you are a novice. If by chance bad electrolytics are the cause, and you wish to repair it, I'd suggest using capacitors designed for these switching power supplies, such as the Panasonic FC series available from Digi-Key and other suppliers. If by chance you do have one of these early rigs, these were excellent units. Most early VCRs were made like tanks, very unlike the "made to break" junkers of the last 10+ years.
Posted on May 21, 2007
Just changed the bulb, TV is about 7 years old. Anyways, I get no power whatsoever after putting in the new bulb. I have tried to unplug and plug back in. The manuel has a main power switch for the 65...
I think if possible a little more information:
master power if it has it will be on back of set and some models have safety switch so if back is off set will not power up.
Do any of the indicator lights (think this model has two) come on or is it total dead set?
No power whatsoever suggests no lights on front of set, let me know as much as you can,
I am in California and will be online for a while.
Steve, SD TECH
Oct 08, 2011 | Optoma RD65 65" Rear Projection HDTV
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
The console will not power up
unplug ac adapter from the wall for 2 minutes and then plug back in . the ac adapter will then reset itself. remember unplug for two minutes.-steve
Jun 25, 2009 | Nintendo Wii Console
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
No response
First follow procedure to try to reset the power.
May 23, 2009 | Acer Computers & Internet
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual: http://es.tripplite.com/support/manuals/index.cfm
u will get will u wan...
Apr 12, 2009 | Tripp Lite Tripp-Lite Internet550U 550VA...
Sharp Acquos power indicator flashing and won't turn back on
Power indicator blinking is an indication that the protection circuit inside the unit has been activated to prevent further damage. You may need to have the unit checked by qualified technician. Most probable cause is a damage component in the power supply circuit or those directly connected to it (mostly output component).
Jan 05, 2009 | Sharp LC-65D93U Television
Samsung HCL552W
these have been know to have bad convergence ic but that would only be a guess as to whats wrong i would have someone give you and est.
Jan 14, 2008 | Samsung HCN4226W 42" Rear Projection...
Power-on "initializing" power-off, repeat same cycle(process)
The all-in-one product display always reads "Initializing" This may occur in a low power situation. Follow these steps in order to determine the cause:
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  4. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Jan 04, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Panasonic AG-1980 S-VHS VCR Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
