Question about Tag Heuer Link Watches
Tag heuer c111a time change how to set time and date
Sapphire crystal i dont seem to be able to change the time and date on watch
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
Brian032472
  • 150 Answers
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Posted on Nov 06, 2008
  • 203 Answers
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
Posted on Nov 22, 2008
escapement
  • 2334 Answers
SOURCE: how to set the time on a tag heuer
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
escapement
  • 2334 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
When Apple watch will be released next year?
There is no specific date as of yet, but it is slated for a Spring 2015 launch.
Apple Watch release date news and features
Dec 01, 2014 | Watches
Seiko instruction adjustment instructions day date
The crown ( the winder as used to be) will pull out one ,two, or three stops. Each stop does somthing different.e.g. 1 - hands, 2 - day, 3 - date. Sometimes, the second stop will do two functions - turn one way for day and the other for date.
Jul 22, 2014 | Seiko SGG713P1 Sapphire Crystal Analog...
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    Something on the face
    take it back to the shop it could be flurescent paint or dust thats got in through the crown on the side but you dont want it getting in the movement any descent watch repairer can do this task it should take no longer than 1hr..to do this job your watch will also need resealing for its water restance to be ok ask if they have a print out with the test result for this task as some of the older water resistant chambers dont have this option its peace of mind .
    Mar 26, 2010 | ORIS WilliamsF1 Day Date Rubber 40.5 mm...
    Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
    Some watches need to have the crown unscrewed.
    Try turning it anticlockwise then pull out.
    If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
    Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Open Questions:
    Watches Logo
    126 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
