My boiler keeps relighting itself every 2-5 minute
Its an old boiler and the pipes tick all the time but every 2-5 minutes, it reignites itself and is using loads of gas
SOURCE: No heat!
I took your advice and got someone in this afternoon. He replaced the pump there and then and all is working well again. He charged £135 for the pump plus labour. It was the best price I could get after ringing around a few other companies. I wish I was a plumber and could charge prices like that!
Thanks a lot for your help.
Posted on Dec 10, 2007
SOURCE: will not stay burning
i think i may have solved it. i heated the thermal couppling and very gently bent the tip about 45 degrees. it has been running about an hour now i'll let you all know if this fails but so far so good
Posted on Sep 06, 2008
burzerko
  • 254 Answers
SOURCE: when the gas boiler comes
This is caused by a weak flame sensing device. As main burner ignitin occurs this creates a roll out condition , when this condition occurs it derives oxygen from the pilot light thus reducing flame signal and causing the pilot to drop off momentarily.
Posted on Nov 15, 2008
  • 70 Answers
SOURCE: Gas log will not stay lit for more than 5 minutes
after you relight have you tried to leave the gas valve on pilot for 10 to 15 minutes so the themolpile warms up enough to send mil-volt signal. you also have a thermocouple that senses flam so if the flame is not hitting that just wright it will shut off. Is this fire place ran off a thermostat or a on off switch. If you are running off a thermostat then i would try to find on/off switch and try that. You might have to change pilot assembly out.If you do this and don't have manual i would take a picture of the log set up so you put it back together. Make sure all connections are tight when you go back together
Posted on Jan 20, 2009
  • 154 Answers
SOURCE: burner goes out
sounds like a bad gas valve
Posted on Aug 01, 2009
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
Apr 03, 2015 | Water Water Heaters
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
My 36 " thermador oven,
The sensor on the burner is not sensing the flame. It could be the sensor itself or its' controller. You need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Thermador Professional Series PO301...
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
We have a Worcester Bosch Highflow 400 (10 year old) combi boiler. Over the last few weeks when we have put on the heating the boiler kicks in and fires up and the heating comes on (the water comes on fine...
The by pass pipe may be limed up. This apparently causes a reduced flow which will stop the heating side of the thing working. Call out Worcester Bosch engineer. It costs £210 including VAT and most parts and they almost guarantee to get it working.
Nov 06, 2009 | Ruud Matching Split Air Conditioner
I have a ravenheat boiler that i have no idea hoe to reignite
you need to reset it but if it dont light you prob have rectifaction fault
Feb 15, 2009 | Calvin Klein The Field Controls Company...
When the gas boiler comes on the pilot light goes out after about 60 seconds then reignites itself a few minutes later.
Nov 09, 2008 | Heating & Cooling
No heat!
Ger, do you get your hot water off the same boiler and it that working alright? How many zones and are they controled by zone valves (little boxes mounted on the pipes) or circulators (small pumps)?
Boiling water sounds can indicate hard water deposits in the boiler or that your aquastat is set too high allowing the water to heat up higher than it should. Check your boiler guage and let me know what temperature you are recording. Get back to me with the answers to my questions, we'll figure it out.
Nov 27, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
