Question about Dryers
My maytag dryer does not heat. model number LDG5910AAW
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
richardsimpl
  • 230 Answers
SOURCE: dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Posted on Nov 16, 2009
SOURCE: My maytag performa pye2300ayw dryer will start but will not heat
maytag performa PYE@#))AYW will run for a few seconds but only if i hold the timer button in and then wil not do any thing for about five minutes??? help...
Posted on Apr 19, 2010
Hwant schematic for Maytag dryer model YMEDE301YGO
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Mar 05, 2015 | Maytag Dryers
Our maytag propane dryer will not heat It appears its not igniting
Usually when a dryer will not heat the problem is a thermostat but... it can be the igniter, the flame sensor, temp select switch or a motor switch. Try a different heat selection (low / perm press / regular and see if the burner lights. If it does light then it is most likely a thermostat. Without a model number I can not pass you specfic information to help you. With the model number I can pass service manual and parts source information. This is the best I can do for you without that model number information from the data plate inside the dryer door on the face of the door cavity.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Maytag Dryers
Maytag dryer model 4000 ayw- spins but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 07, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
I have a maytag dryer model number is mce8000ay
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How to turn on pilot light maytag neptune dryer
Thing is the dryer does not have a"pilot" it has an electric ignition system with and electric igniter. Go here for more: Dryer Repair Help
Go to RepairClinic.com and enter your model number into the Search box at the top of our website to see all the parts available for the unit.
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Electric maytag stack dryer not heating...
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Dec 14, 2008 | Maytag SDE2606 Electric Dryer
Dryers Logo
Top Dryers Experts
