FixYa.com
Tags:
Panasonic VIERA TH-65PV500 65 in. Plasma Television
Viera Plasma (by 5 users)
posted by brcmb on May 21, 2007
My Viera 42'' is new , just one week old.
Today when i try to turn it on, the red led kept flashing, but no images come on, it all black as if its off . Can you please help me to find a solution ???
cheers
Bruno
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by jo_irons, posted on Jul 20, 2008
Hi, we have a similar problem, tv (42" viera full HD) is less than a week old - worked fine for 2 days after installation, then switched on today and got the green light followed by red flashing light, but 11 flashes. No images/sound at all. Have tried resting it for 30 minutes, unplugging from surge protector socket/changing power sockets, also the holding in power button solutions suggested. Help! The number of other posts is worrying - not sure if I want another one, this is my first plasma. Jo, Queensland.
Comment by Guest, posted on Apr 29, 2008
Panasonic th-42pz700u
Using the remote to turn the unit on, for a second the sound came on. after this no picture/sound. 7 Red blinks on the power indicator...
Unplugged from the surge protector, direct in the wall and back again all with the same result. No picture/sound - just 7 red blinks.
It will be serviced within a few days/warranty.
However, reading that I am not the only one that experience this problem and as there seems to be a structural problem wondering if this 'brand' is wrongly marked as the "number one."
thanks for this opportunity,
best regards
tom
Comment by PKCambridge, posted on Dec 30, 2007
Very similar problem, TH-PZ77U, brand new, has not yet "worked" as every attempt to turn it on has it come on for maybe 2 seconds, appear to work then shut down on its own. Red flashing series of 11. Have tried disconnecting all peripherals, connecting in different configs, totally removed and plugged into different electrical socket ... all with no success. Have submitted questions to Panansonic technical support but of course nobody is working the weekend. Stressed to see so many internet posting of similar issues. Paul in Cambridge Ontario
Comment by Kezz, posted on Dec 10, 2007
Hi I am in Australia and having a similar problem. I have a TH-42PZ700A (not recognized on your forum) that is only a week old. After working fine we tried to start it and the light flashes green as if for a normal start up. Then there is a split second of sound and the light changes to red and flashes in a repeating 7 flash cycle.
We have tried turning off for over an hour. We have tried an alternative power source and holding down the chanel change button. We have also tried not using the surge protector and plugging directly into the wall socket. Finally we tested the power outlet and surge protector and found it to have a stable power supply.
Any other suggestions or explanations would be greatly appreciated.
Best Solution
posted on Mar 07, 2008
FixYa! (100)
xmarine2847
Rank:Wiz Wiz
Rating: 88%, 48 votes
When the power light blinks the set's protection circuits are causing the unit to shut off and blink. The series of blinks is an SOS signal that a servicer can decode to help diagnose the problem.
For those in areas other than in the US, I can't really say what the issue might be as the SOS patterns may be different for different countries. But, if you can find a service manual for your area you should be able to at least get an idea of what might have happened to it. There's no guarantee that what you read is the actual problem without further testing, however.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 25, 2007
Helpful (85)
flack
Rank:Master Master
Rating: 80%, 13 votes
I had the same thing happen with another one of these screens. Try and unplug it for 30 min and plug it back in. I did this to another screen and it has worked ever since. Let me know if this works for you
Solution #3
Helpful (85)
Kezz
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
I ended up returning my TV to the store I bought it from. Apparently the 7 flash sequence (at least here in OZ) means that the power module that regulates the power supply inside the unit is faulty and therefore as a precaution the TV will not start. Apparently this occurs in around 2% to 5% of all units. While under warranty the unit should be replaced by the seller - after warranty then you will need to pay for a service rep to repair it.
Solution #4
posted on May 23, 2008
Helpful (85)
8x10
Rating: 78%, 2 votes
I had that problem, but with 10 blinks of the red flashing light. Solution was to press & hold the power switch on the TV -- that resets the switch & then it worked again. Will be watching with my fingers crossed & will keep the box just in case.
Solution #5
Not Rated (0)
jo_irons
Rating: 0%, 0 votes
Hello, found a solution (see our problem above), I hope, touch wood, everything crossed. We had red light flashing on 11 time sequence - unplugged tv from mains for about an hour, then plugged back in and miraculously it came on. TV is obviously more canny than we though it could be. Could this a cautionary measure due to a small power brown out/drop? I know we are in an area prone to them (and surge protectors don't help). Anyway, wish us luck it doesn't happen again. We had a nice night listening to music in candlelight instead!
Solution #6
posted on Nov 25, 2007
Not Rated (0)
dallistone
Rating: 0%, 0 votes
Not sure if this helps or is relevant, but I just had the same problem. I had the plasma plugged into a power bar when I experienced the red flashing light/no power issue. The problem seemed to correct itself when I plugged the plasma directly into a wall socket.
Can you Help with these Flat Panel Televisions problems?
Panasonic VIERA TH-65PV500 65 in. Plasma...
Black box in center of screen
A large black box popped up in... Answer This...
Panasonic Viera TH-42PZ800A
When watching AFL ( Australian... Answer This...
Panasonic 42PZ700U
No picture, no sound, red light... Answer This...
connect surround sound to...
durabrand surround sound... Answer This...
Panasonic HDTV rear projection
Won't turn on and has red... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
