Data Becker Music Center Pro wont work on windows xp
I have been using Data Becker Music center pros on wmy windows 98se and it worked great. Now I havw updated to XP and tried to install the program. Once it wouldn't let me. Then it did but it wouldn't work even though I set it to run under windows 98. Can I et this program to work on XP?
  • Anonymous Apr 23, 2009
    Tried installing Music Center PRO on a VISTA (Home premium) operated laptop and it hogged all 2GB of memory and still wouldn't work. While installing it the unistall program did not install properly so now I can't remove the program properly. Very disappointing!
SOURCE: Photo Explosion Deluxe - install
Cant get it to install on my computer either... run time error... run time error... think I'll go get my money back!
Posted on Jan 12, 2008
SOURCE: Claris Draw v1.0v3 will not start with XP
Right click on the Claris Draw program icon and open properties box. Then select "Compatibility" tab.
Under Compatibilty tab, check "Run this Program in compatability mode for:"
Select Windows 98/ Windows ME option from drop down menue.
Make sure "Claris" folder is in C:\Windows
Now do following whenever you thereafter want to run Claris Draw:
Try to open the Claris Draw program and you should get message saying it can't find Claris directory.
In the message box, browse down to Claris directory and double left click it.
Then left click on any file in the Claris directory window.
Now left click on the Claris directory again, but hold the left mouse button down.
The OK button should stay lit while you are holding the left mouse button down.
While still holding the left mouse button down, press the "Enter" key on your keyboard.
Claris draw should now run.
This nutty start up procedure seems a little complated, but once you get the hang of it, it takes only a few seconds to do it.
Posted on Dec 18, 2008
allanster
  • 60 Answers
SOURCE: iTunes installation problem
This happens occasionally when downloading something, a portion becomes corrupted. Try throwing that one away, redownload, and it should work. If it doesn't restart computer and then try installing the freshly downloaded one again.
Posted on Jan 23, 2009
SOURCE: I can't install Data Becker CD LabelMaker On Windows XP
I can't install labe databecker 98 version. I have window xp
Posted on Apr 25, 2009
  • 52 Answers
SOURCE: Windows Movie Maker wont Publish video
Random suggestion that you have likely already tried. After you uninstalled did you go to your c drive, program files and delete the folder? I had issues with another program and found that the existing folder was the problem. After I deleted it and rebooted and then installed again it worked perfectly.
Posted on May 26, 2009
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
Repairing windows (wmi) on windows xp ser. pk. 3 not wanting to replace the os in the process.Restoring to an earlier date isn't working, says its unable to restore to that date.But, anyway finding that...
Microsoft has released a new diagnosis tool that helps system administrators diagnose and repair problems with the WMI. It is advisable to go through the WMIDiag_ReadMe.doc file to understand how the utility works, and the supported command-line arguments. Here is the download link: The WMI Diagnosis Utility
You may use the utility (WMIDiag.vbs) to find if a repository rebuild is necessary or not. The utility runs a comprehensive testing of WMI and reports the results to a log file, which is placed in the user's Temp folder (%Temp%) folder by default.
Mr. Alain Lissoir [MS] was kind enough to share the following info with me:
If there is a need among all problems detected by WMIDiag to rebuild the repository after attempting all fix suggested by WMIDiag, WMIDiag will list the rebuild of the repository as the last action among thing that can be done (before rebuilding the repository).
Here are some of the useful links that I came across from Alain's homepage:
Mar 24, 2010 | Microsoft Windows XP Professional With...
Cam won't work on windows 7
That particular Cam is for Win 98SE, 2000, ME or XP so won't work on Win 7. The Logitech Pro 9000 will work with Win 7 and is HD quality and excellent audio (Amazon has great deals on them). Google Logitech Vid if you get one then send an invite to connect to your contacts. They too will have to download the Logitech Vid software for 'Live' calling, and the Cam will work in MSN Messenger.
Jan 26, 2010 | GE MiniCam Pro HO98756 Webcam
Keep getting error message to unlock scanner.....says it can be unlocked from the bottom of the scanner, but I don't see it.
My one touch 5800 USB scanner worked great on XP for over a year and then started giving me the unlock the scanner message. I tried different power supplies, reloading software and moving it to a machine running 98SE and nothing improved. I left the cover open and noticed that the lamp was fairly bright at the sides but very dim in the center. I replaced the lamp with one from an old parallel port scanner which was in good shape and it now works perfectly on 98SE. I have not connected it to a XP machine yet.
Aug 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Windows media center on start up freezes computer, why
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
Windows xp media center error occurs when trying to record programs
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
The help and support center in windows XP pro not working
restart your computer once and check....
if it still does not work... the help and support files have been deleted...!!!
Jan 28, 2009 | Microsoft Windows XP Professional
You asked a long time ago. If you still use XP get Plus! for Windows XP, which contains a label creator programme based on the Data Becker software. Works perfectly.
Jan 19, 2009 | Databecker Instant LabelMaker (2087368)...
Help
Ok when you hook it up and it says MTP just push and hold the Play pause key till it says Usb then it should recognize it .....
now mine recognizes it on both usb and mtp i have win xp pro ...  If you do this and it doesnt work
If you are using Windows XP or Vista, make sure that the player is in the Media Transfer Protocol (MTP) mode. This can be done by pressing the M button. This button is located on the top of your mp3 player. Open Windows Media Player 10 or 11 and follow the directions for transferring (synchronizing) music. If you have Windows Media Player 9 on your XP machine, upgrade to Windows Media Player 10 or 11. This can be done by visiting www.windowsmediaplayer.com.
If you are using Windows 98SE, Windows ME, or Windows 2000, you will only be able to transfer music using the USB transfer mode. Open Windows Media Player 9, and follow the directions for transferring (synchronizing) music.
If you have version 9 on Windows 98SE or Windows ME, you will need to visit the Download Center for updated drivers.
Jan 15, 2009 | GPX MW-238B MP3 Player
I have a gateway lb3 500 ancient 98se i tried to load xp pro and it crashed i cant seem to even get a 98 startup disk to work to recover it . how can i recover it to load the xp pro onit
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
Dec 07, 2008 | Computers & Internet
Computers & Internet Logo
666 people viewed this question
David Payne
David Payne
