Question about Hunter 27185 Remote Control
How do u change the frequency on remote hunter 27157
SOURCE: what type battery does the
It's a 12v battery, I found this battery in CVS and it was an energizer battery.  It's about half the size of a AAA battery.
Posted on Feb 22, 2009
SOURCE: No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Posted on Jul 16, 2009
  • 208 Answers
SOURCE: we have three hunter fans w/ remotes. need to
Hi, unless the fans/ remotes have code/ identity setting switches, then not possible.
you could however try shielding the front of the remote (simulating a tube) so the IR beam can be selectively pointed at each fan for individual control (works well for TV walls)
Posted on Mar 19, 2010
Testimonial: "Thank You for your input I shall try it "
  • 4 Answers
SOURCE: I installed a Hunter On
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Posted on Aug 08, 2010
  • 3 Answers
SOURCE: Can this remote (hunter 27157) be paired with a
I know you can use many different remotes of the 27157 model to control one receiver. There are several different reason why you may not be able to use the remote from one brand/model with another. The first is the frequency range may be different. One could be 27mhz and another could be 49mhz. Another reason is the code that is sent to the receiver by the remote to turn on the light or the fan varies from manufacturer to manufacturer and even from one model to the next from the same manufacturer. This is so there is less chance one remote/receiver commbination will interfere with another in the same location. That is why I say you will be very lucky to find an off model remote to work with your receiver.
Posted on Aug 15, 2010
Jumpers
Download the service manual to this fan. It has all details. It is in PDF format. So I can't send it to you by this window.
Mar 21, 2013 | Hunter 27157 Remote Control
Instruction for a hunter remote model 27157
this is the hunter technical support--1-888-830-1326 just ask for support. then you should be able to order the instruction manual.
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
Can this remote (hunter 27157) be paired with a fan that is already installed and has a remote. I want to use it as a backup. the remote i have is not a 27157.
Aug 06, 2010 | Hunter 27185 Remote Control
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Mar 27, 2010 | Hunter 27185 Remote Control
Jun 24, 2009 | Hunter 27185 Remote Control
What type battery does the Hunter #27157 remote use?
Nov 11, 2008 | Hunter 27185 Remote Control
Fan and light control model 27157
yeah, if you take off the battery cover on your fan remote there should be something called a "dip switch". it wiil be numbered 1,2,3,4, just flip these switches up or down to match the receiver that will be located in the fan houseing or in the fan canopy.
Sep 19, 2008 | Hunter 27185 Remote Control
Ceiling fan, remote control
I call some one here is the USA a he walked my thru it, Its is a big different when you deal with some that speek your language
Jun 08, 2008 | Hunter 27185 Remote Control
Televison & Video Logo
49 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
