Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
VCR Time Setting
My VCR will not program to 2009. Is there anything that I can do?
  • 51 Answers
Set your VCR to either 1987 or 1998. The dates are the same.
Posted on Jan 04, 2009
I have a reconditioned VCR HS-521V(IR) and I want to set the date but the year ends at 2009. can I change this date.?
Unfortunately no! the vcr has a built in calender that is limited to the year 2009 that was programmed at the factory. The only way to change this, is reprogramming it with specially equipment.
Apr 08, 2011 | Mitsubishi Televison & Video
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
Analog VCR Model SDV394SU on cable will tune stations and record the current station, but will not start for for programmed (on/off timed) recording. In other words, when you program the VCR to start at a...
The answer to your question, "Does this have anything to do with the fact that the VCR and TV are now on cable?" is no.
The outside antenna and the cable are input signal sources only and have no effect on the functions of the VCR.
It sounds like you have an electronic problem with the timer circuitry. In order to locate exactly where the timer circuitry is located, you would need a service manual for your particular VCR. Using the service manual, you may or may not be able to repair it.
My suspicion is that it would be cheaper to just purchase a new VCR if timed recording is important to you.
Aug 07, 2009 | Toshiba Televison & Video
VCR will not go to date 2009
I wish you luck on your search for an answer, but vcr's are programmed for a possible life expectancy.  So ur vcr was expecting to be in a landfill by january 2009 and according to its programming there is not a 2009.  Combo units at walmart are realativly cheap now a days I would recommend picking up a new one.
Jan 03, 2009 | Electronics - Others
Magnavox VCR U095 39760450-can not put in 2009 YR to record
I called Magavox and Matt told me they had no information for my very very old vcr. He suggested that I trick the machine and use a date similar to the current calendar. For instance, today is Monday, January 5th. I went back to 2004 and found the same day and date. I programmed my vcr for 30 minutes to test it out and it worked. If you can't beat it, join it. Hope your vcr works too. Happy new year!
Ilene
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR won't record at programmed time
Check the clock to make sure the AM and PM setting is correct.
Oct 08, 2008 | Sansui Televison & Video
Setting the clock/time
There should be a menu button on the remote which will get you into the various advanced programming functions. Many/most of the late VCRs cannot be programmed, time set with the buttons on the VCR itself.
Mar 12, 2008 | Televison & Video
VCR Won't Record Sound
Some VCR have the ability to record sound from another source. Check the sound settings and record settings to make certain it has not been switched to another sound setting.
Oct 03, 2017 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
