Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima WD71 - floods on drying programme
When it flood the water comes from the rear of the machine. It works fine as a washing machine still. Any ideas what might be causing it and how to cure it? Any help much appreciated
  • danieljmills Jan 28, 2009
    Many thanks for that, I'll have a look this weekend to see if I can find it
    An expert whose answer gotĀ voted for 100 times.
  • 100 Answers
You may have a hose loose or holed at the inside rear of the machine.
Posted on Jan 27, 2009
Just keeps filling at the start of program and displays H20
Your washer has a bad water valve or fill censor telling machine need more water then to much water sends a flood warning shuts down so will not flood your home look for small clear tube coming from tub to a type control hose may just came off
Mar 09, 2015 | Hotpoint Ultima WF860 Front Load Washer
Water feed does not cut off and machines fills up and FLOODS
Your problem could be one of the following:
* water level/pressure switch
* water valve assembly
Contact an appliance service company.
Feb 17, 2010 | Hotpoint Ultima WF865 Front Load Washer
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD71 washer/dryer
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Oct 17, 2008 | Hotpoint Ultima WD72 Front Load...
Hello john walker24
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Do anyone know what e11 mean on hotpoint wd71 pls
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Mar 27, 2008 | Washing Machines
Wd71 error 34
get a washboard and a jug
Feb 14, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Aug 23, 2007 | Hotpoint Ultima WD72 Front Load...
Check water supply error F11
pump cannot be activated:check pump , connections and wiring
Sep 12, 2006 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
108 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
