Question about Ovens
Oven locked up
For my new Whirlpool drop in range, i was using the oven for the first time, when it reached 350* it beeped, as it was supposed to, then a moment later there was a POP sound and i looked at the display and the clock is off, and ''bake'', ''broil'' ''hold'' ''warm'' ''clean'' and ''delay'' are all lit up red and the controls do not respond.
The ranges still work.
I shut off the breaker and turned it back on and it's still all red.
  • 81 Answers
What breaker did you shut off? House breaker? Or the ovens internal breaker? My drop in has a set of push button breakers under the oven behind a fold down door. The fold down door is in place of a regular ovens pull out drawer. Check in there if you have one. The light are more than likely a warning somethings wrong. If this was just installed check to make sure it was grounded properly. Also check to make sure the AMP rating of the stove and the one in the house breaker box match up. The house one can be higher but not the other way around. Hope that helps.
Posted on Jan 04, 2009
Random beeping oven
Check the connections to the oven heating element for oxidation. If the wire insulation at the connector looks like it has been overheated, you almost certainly have a bad connection.
Nov 12, 2017 | Whirlpool RBD306PD Electric Double Oven
Whirlpool gas oven is taking three times as long to cook something,what is wrong?
have you checked with an oven type thermometer for 350 degrees against the setting of 350 degrees,if its off very far then its the oven temp sensor in the upper left middle or right rear wall of the oven thats bad it looks like a small pencil type rod 2" to*' long it merely unplugs off the oven s control panel in the rear,you can test its resistance also to get an idea if it is your culprit,otherwise the oven element could have a hot spot in it and not letting all the current thru to properly heat the element,it will be dis-colored in that area
Nov 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
My whirlpool range model#rf114px513 started
You will need to press the stop /cancel button this will clear the display
Nov 15, 2009 | Ovens
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
76 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
