Question about Nikon D90 Digital Camera with 18-200mm lens
It is possible to turn off the LCD backlight from the menu, but when the camera is turned off it defaults to the LCD backlight on, and the card access light continues to flash, and the battery drains
This just happened whilst the camera was not being used! The battery was not changed or even a fully charged "hot" one. Suddenly the battery was completely flat so that there was no display at all on the LCD. Replacing the battery with a fresh one brought up the problem with the LCD backlight being permanently on and the issue of the card access light flashing even when the camera was turned off.
    New Friend:
  • 3 Answers
Have you tried a factory reset/firmware upgrade? May be you should give it a shot.
Posted on Aug 08, 2017
  • 48 Answers
SOURCE: Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Posted on Mar 02, 2009
  • 17 Answers
SOURCE: My D40X won't turn on!
It is required to solder a main pcb.
Posted on May 13, 2009
  • 5 Answers
SOURCE: Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
Posted on May 29, 2009
jimsilva
  • 6 Answers
SOURCE: Same Problem
Send it to Nikon.
Posted on Jun 26, 2009
  • 11967 Answers
SOURCE: just bought a used d300 and it won't power up. It
Sometimes, checking the battery's voltage discharges it. Try not doing that once and see what happens. Also, it wouldn't hurt to clean the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Sep 30, 2009
What do you do when camera says internal memory filled.
Digital cameras store pictures on their internal memory. Often users transfer their photographs to memory cards, because memory cards store more data and are accessible in computers, other digital cameras and other devices. When you want to move pictures stored on the internal memory card, do so through the camera's menu
1 Place the memory card into the digital camera.
2 Turn on the digital camera.
3 Access the digital camera's menu. Digital cameras have a button labeled "Menu" near the LCD screen. Push this button to open the menu.
4 Select the Pictures option. Select the photos on your internal memory using the "Select" or "OK" button on the arrow pad on the back of the camera. Click "Copy" and choose "Memory Card" to copy the files to the memory card. If there is more than one picture that needs copying to the memory card, perform this step for each picture.
Have a good day! Smile : )
Sep 04, 2011 | Kodak EasyShare V803 Digital Camera
I replaced the lcd screen. Now when the my camera is turned on i have a black screen with nothing on the lcd. Not even a menu display. I have pushed the lcd ribbon as suggested but no luck. Need advise....
The backlight is not turning on, it's the smaller of the two ribbon cables on the LCD assembly.
Make sure you have a backlight on your new LCD (not everybody sells it with the backlight!) or reuse your old backlight with the new LCD.
Check the backlight cable, is it ripped? Even slightly? If so, you need a new backlight.
Thomas Drayton
Owner Darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Canon PowerShot SD870 IS Digital Camera
No appearance of LCD Backlight
Turn the dial, on top, to menu
Under LCD Backlight <select on>
Mar 25, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
Hello, my camera doenst complete the access and than tell me to (turn off and try again). all i can see is the info on the memory card. Can u help me please?
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Backlights (LCD or keypad) not working on brand new handsets
Could they be turned off by default? Find out how to get to the menu and check this out.
Sep 25, 2009 | Vtech CS62192 Cordless Phone
My acer extenza 4420 backlight wont turn on
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Aug 31, 2009 | Acer Extensa 710TE Notebook
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Lcd screen stuck in usb mode?
Try removing batteries and card and leaving them out for a while to allow camera settings to default.
Replace batteries only and see if you get "Card Error" message.
If you get this, then try again with card fitted
Check firmware version
Possibly card storage too big. Upgrade firmware to version 1.77
If you have no user manual there is a PDF version available to download here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a330-zoom/Support
All the error messages are given in the manual with possible solutions.
Aug 25, 2008 | Fuji FinePix A330 Digital Camera
Camera lens
Does the camera take pictures?
If you take the camera near a lamp, can you just about see menu items on the LCD?
If so, it's possible that the backlight ribbon cable slipped out of the socket. To check open up the back of the case and carefully lift it up a bit just to see the ribbon cables. The narrow one is used for backlight. Try to disconnect it (open the tiny black flap in the connector) and connect it again (close the black flap). Have a quick look at the connectors on the ribbon cable and make sure they are clean. If it still doesn't work I'm afraid most probably you have a faulty backlight and will need to replace either the whole LCD (easy) or just the backlight (fairly fiddly job). In any case, you'll probably need a donor camera (ebay ;) to scavenge for replacement LCD.
Good luck,
Raf
Jun 17, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera
Try to get any menus with out the camera plugged into the PC or any card inserted.
Will it get a menu?
If you still have NO MENU and Nothing on the screen, the problems deepen.
Possibly a defective or broken LCD.
If any of the lites turn on when you turn on the camera and no LCD shows, you may have a bad LCD.
Appears to need some kind of repair.
Here is a link for further info.
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Oct 09, 2007 | Vivitar ViviCam 5100 Digital Camera
Nikon D90 Digital Camera with 18-200mm lens Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
