Toshiba Equium 3200M  PC Desktop
Problem for Toshiba Equium 3200M (PV1058U-4CNS2) PC Desktop
Toshiba Equium 3200m hard disk upgrade
By nickosm on Jan 04, 2009
Dear All,
I need to replace an 20G HD with an 80G HD on a Toshiba Equium 3200m desktop pc (PIII 500MHz, 256M RAM). When I remove the 20G HD and plugging the new 80G HD the pc can't find the HD. COuld you please advise how to solve this problem?
Thanks in advance
Comments:
Jan 24, 2009
- Thank you!
Clarification Request
Posted by DickCanFixIt on Jan 04, 2009
Your old motherboard is not capable of recognizing the new drive without some help. Go to the drive manufacturer's website, download and run their utilities to pre-configure your drive and allow your BIOS to work with it.
On such an old system you may not be able to do it at all. But should you post your drive make & model someone may be able to at least point you in the right direction.
Best Solution
posted on Jan 04, 2009
Helpful)
JT-LV
Rank: Wiz
Rating: 81%, 16 votes
From all of the specs, it appears that is motherboard only supports up to a 20GB drive. The way to add this drive is to buy a separate hard drive controller, but honestly that is a waste of money. By the time you finished adding pieces and parts to get everything to work, you will have replaced so much that you could buy a new system and alos have issues wiht some things not working.
Dell has a low end desktop for on $399 and you can find some things even less than that in their refurb section, with a warranty, for less.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Equium 3200M PC
Questions and Unsolved Problems for Toshiba Equium 3200M PC
Do you recommend Toshiba Equium 3200M (PV1058U-4CNS2) PC Desktop?
Answer
Answer
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm... (More)
Answer
connect to gnutella network
Answer
gnutella network
Answer
half of the screen has the start up and the other half is the desktop icons
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Equium 3200M PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
