Question about Epson Aculaser C1100 Printer
What is k toner in a c1100 printer
Epsom c1100 k toner which colour is
SOURCE: Black Toner replaced
This is what happens when you also do a refil, but the advice from the refill people is to ignore the low ink warning as it will print happily until the point that the next message comes up which is that you need to replace the toner. Effectively this is to do with teh chip in the cartridge thaht tells the printer that it is low and unless you buy a new cartridge you will still get the low toner message but it is safe to ignore.
Posted on Oct 25, 2007
Soulvisitor
  • 1113 Answers
SOURCE: replace toner k
Replace black toner with new
Posted on Nov 27, 2007
  • 4 Answers
SOURCE: Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Posted on Mar 06, 2008
SOURCE: Epson Aculaser C1100 will not print properly after changing black toner
I have had this problem with a couple of our C1100's the solution is simple but a bit fiddly.
open the lid and remove the photoconductor unit. what you need to do is clean the glass panel through which the laser shines (it is there honest). It id directly behind the toners but down near where the paper sits. Look at the photoconductor and see where the blue roller sits in the printer. This roller has the laser shone on it and then picks up the toner relaying it onto the belt in the photoconductor.
What i did was get a wad of strong tissue and use a screndriver to wedge it down the rear of the toners (in between the toners and the black plastic bar as you look into the printer with the photo conductor removed) and then slide it back and forth. I actually learned this one form some Minolta QMS printers we have, but the glass plate was in plain view on those.
Basically what we had happen was that some toner had dropped onto the glas and was blocking the laser from hitting the roller and this lead to blank (or faded) strip along the length of a page.
I suppose a smallish paintbrush would do the same thing.
Posted on Dec 23, 2008
SOURCE: what colour is K on low ink
Toner K low refers to the black toner.
Posted on Jul 03, 2009
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
Jul 17, 2012 | Epson Aculaser C1100 Printer
Epson acculaser c1100 ink replacement
K- black
M- Magenta (red)
Y- Yellow
C- Cyan (blue)
Hope this helps.
Jul 03, 2009 | Epson Aculaser C1100 Printer
What colour is K on low ink
May 15, 2009 | Epson Aculaser C1100 Printer
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
How to change the balck toner only in the epsom aculator c1100 showing K toner low, but blue at the place the black should be?
Epson C1100's show toner low for a long time before it actually needs replacing (usually have another 500 - 1000 copies left). This is to give you time to order a new one. When it is completely empty you will get a message saying replace K toner and the cartridge will be moved into the front position ready to remove it. If you really must replace it before it is empty let me know and I will try to explain how to do it, although it is quite involved.
Please take a moment to rate this solution. Thanks.
Mar 03, 2009 | Epson Aculaser C1100 Printer
Replace k toner
hold down the dustbin button while switching on to reset the printer after cleaning. that worked for me.
Sep 03, 2008 | Epson Aculaser C1100 Printer
Mar 04, 2008 | Epson Aculaser C1100 Printer
Epsom C1100 - Changing cartridges
On the left hand side of the cartridge door, there is an actuator that disconnects the carousel latch, allowing you to manually turn it. You should then be able to remove the incorrect cartridge.
Hope this helps
Stu
Nov 02, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
