Question about Haier Washing Machines
F1 error Haier Washing machine
Haier XQB55-10H fully automatic
5 Suggested Answers
  • 133 Answers
SOURCE: F1 error code
This was copied from a website called WORLD OF WASHERS....I just copied the whole paragraph......sounds like some $$$
Let me know if this helps.......mtg
I am new to this online blog stuff, so I figured an email would be best. I own a Kenmore Elite Oasis washer Model #110.27042602. Everytime we try to use the washer we get error code F1 flashing. This happens withins seconds of the machine first starting to fill and about ten times thereafter until enough water gets into the tub for balance, I assume. We have started pouring about 2 gallons of water onto the clothes in the tub by hand before starting the machine which usually works. About half the time the machine stops again between wash and rinse cycle as it starts to fill with water again.
In my online research, I guess its good we don't have error code F51, but this is a pain and 1 year warranty has passed. It appears I may need to get a new Machine Motor Control Assembly. Any thoughts????
Thank you,
Darrell S.
Darrell,
I'm probably not going to tell you anything you don't already know. You know you may have to replace the motor control assembly, so you have done your due diligence.
I found a thread related to your problem at the "Samurai Appliance Repair Forums" at ApplianceGuru.com. That link will take you to the discussion, in case you haven't already read it. The poster described a situation identical to yours, and I have also read of this problem at other sites on the web.
Contained within that thread is a link to a Service Matters (Whirlpool Corp.) tech sheet related to the F1 error code. This is the document any qualified servicer will refer to when addressing your problem. Here is a link to that sheet in case you want to have it on hand in the event of a service call.
The tech sheet calls to replace the control, but only after three other tests have been conducted. Everything I have read indicates the control will be replaced the vast majority of the time. I am not a technician, but I would say there really is no way around that.
Please keep in mind that this sheet applies to specific models and serial numbers within the Whirlpool line. There may be a separate sheet for your washer, but I imagine the end result is the same.
The million dollar question is how much will such a repair cost. I am seeing prices ranging from $150 to $200 just for the part. With labor, you will probably have at least $300 invested in this repair. I would encourage you to contact Whirlpool at 866-769-7260. I have read instances of other owners receiving satisfactory service in out-of-warranty situations via this number. Whirlpool knows these washers are ****, so they no doubt have a scripted procedure in place to deal with these situations. Be firm, but also be polite. Maybe drop the word "recall" and see what happens.
Posted on Apr 11, 2009
AviatorF18
  • 29 Answers
SOURCE: i have a Haier XQBM22-C washing machine and it displays error 7
Here's the user's manual: http://service.haieramerica.com/documents/User%20Manual%20XQBM22-C.pdf
Here's the service tec manual: http://service.haieramerica.com/documents/WD-8888-72.pdf
Posted on May 27, 2009
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
SOURCE: Error code 7
You need a new motor.
Posted on Feb 04, 2010
I have a Haier 75-981 Automatic Washing Machine (Top loader) that is displaying an error code FA. What does this mean?
Feature : Error Code-control panel display "FA"
  • Answer : Reason:Water level sensor error.
    Solution:Please unplug the machine and close the water tap, then call for service
Mar 15, 2018 | Haier Washing Machines
My haier hpp12xct-lw is accumulating water in air mode
So it's likely not fully evaporative. Must be high humidity and auto evaporate can not keep up. It just means your unit is working great. Drain it!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 10, 2017 | Haier Heating & Cooling
I have an haier front loader washing machine hwm80-1403d and it is flashing an error3. What can I do have never used it.
Hi!
On Haier washers error 3 means "Detected washer temperature sensor error"
Check connections to washer temperature sensor.
Check temperature sensor.
Jan 07, 2017 | Haier Washing Machines
Haier dryer RDE350AW
Use timed drying setting
Dec 17, 2016 | Haier Dryers
What is the err 1 code on a Haier washing machine model HWM1070KFL
Maybe something wrong with the door switch for error code 1.
Mar 03, 2015 | Haier Washing Machines
Haier washing machine keeps stopping and displaying error code E1
As said in the question you are haier washing machine keeps stopping and displaying error code E1 this is due to the Error signal due to Pr. Sensor.This problem can be solved by only service Engineer.Thanks for your question.
Jun 20, 2011 | Washing Machines
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
